Ls2 408 stroker
Old Sep 5, 2019 | 07:04 PM
  #221
spanks13's Avatar
^^Thanks guys, confirmed my last post what I found elsewhere. Neat info. Sorry for the derailment!
Gotta do something while we wait for the next dyno sheet...lmao
Old Sep 5, 2019 | 07:20 PM
  #222
Darth_V8r's Avatar
Moderator
LOL. Pour Bortuous.
It is cool stuff though. Here's one thing too, you can look at spring pressures etc, but we have not even added in the force required on the exhaust valve to open it. Combustion chamber is X psi in addition to the ~700 lbs spring pressure on the power stroke. For simple math, let's use 1000 psi x 1.65 exhaust valve diameter is 1650 pounds PLUS the spring rate! Asking a LOT out of that poor pushrod!
Old Sep 5, 2019 | 07:23 PM
  #223
ddnspider's Avatar
Needs turbo
Old Sep 5, 2019 | 08:57 PM
  #224
bortous's Avatar
Haha.
I wish I could post the final dyno sheet with proper results.
Old Sep 5, 2019 | 09:46 PM
  #225
bortous's Avatar
This pushrod discussion is interesting.
I think this question has already been answered.
First of all I spoke with my tuner in regards to pushrod size fitment in my ls3 heads.
He says the 3/8 size will definitely not fit however the 11/32 will fit as it's in between the 5/16 and 3/8 size.
Can someone tell me a fact.
How much stiffer is a 5/16 ..80 compared to a Manton 11/32 .145 thick?
How high can I go in wall thickness in the 11/32 size and still have clearance?
I went on Manton's website and they have so many options for the 11/32 diameter.
We do not have Manton here in Australia and I have found a seller on Amazon that has the size I need.
Old Sep 5, 2019 | 10:22 PM
  #226
lazerlemonta's Avatar
I have the manton series 5 11/32 .120 wall. You should really be measuring every push rod for proper valve train set up.
Old Sep 5, 2019 | 10:29 PM
  #227
bortous's Avatar
I have. This is the size I need. I also require a 7.800 length.
We do not have these high end pushrods available down here in Kangaroo Island.
Old Sep 5, 2019 | 11:10 PM
  #228
Darth_V8r's Avatar
Moderator
The manton you listed will be at least twice as stiff as the ones you have now.
Old Sep 5, 2019 | 11:15 PM
  #229
bortous's Avatar
So a Manton 11/32 .120 wall is also twice as stiff as a 5/16 .80 right?
Old Sep 5, 2019 | 11:32 PM
  #230
Darth_V8r's Avatar
Moderator
Yes sir
Old Sep 6, 2019 | 12:40 AM
  #231
bortous's Avatar
Yes sir
Another question.
When you say twice as strong is this compared to the series 3 or series 5 manton pushrod?
I checked the pricing for the Manton 11/32 .145 in series 5 and they are 532.00 USD plus shipping!.
I found an 11/32 .120 wall Manton pushrod but it's from the series 3 line.
Old Sep 6, 2019 | 02:15 AM
  #232
Darth_V8r's Avatar
Moderator
That would still be way superior to what you have now
Old Sep 6, 2019 | 08:54 AM
  #233
bortous's Avatar
Can you tell me if lt1 pushrods are compatible with ls?
im thinking of getting these from amazon
https://www.amazon.ca/Manton-Pushrods-Billet-2014-Up-Diameter/dp/B01FPONK52/ref=mp_s_a_1_13?qid=1567720866&refinements=p_4%3AManton+Pushrods&s=automotive&sr=1-13 https://www.amazon.ca/Manton-Pushrods-Billet-2014-Up-Diameter/dp/B01FPONK52/ref=mp_s_a_1_13?qid=1567720866&refinements=p_4%3AManton+Pushrods&s=automotive&sr=1-13
Old Sep 6, 2019 | 09:22 AM
  #234
AINT SKEERED's Avatar
https://www.amazon.ca/Manton-Pushrod...motive&sr=1-13
I'm using trickflows 3/8x.80 for BBC. As long as tips are same, so yes an lt1 of proper length should work
Old Sep 6, 2019 | 09:33 AM
  #235
bortous's Avatar
Can you tell if those pushrods in the link at the dual taper version?
I can't tell
Old Sep 6, 2019 | 10:37 PM
  #236
I can't tell
They seem to be but u can't guess either. I'd call and talk to them or send an email
Old Sep 6, 2019 | 11:27 PM
  #237
bortous's Avatar
Can someone please tell me what radius tip size do I need to order for my pushrods?
Been going through Manton and they have a 180 and 210 degree pushrod tip radius option.
Which one do I choose?
Old Sep 7, 2019 | 09:24 AM
  #238
Darth_V8r's Avatar
Moderator
Not sure. I call them up when I order and when I say LS they know which tips to use. My gut says 210
Old Sep 7, 2019 | 09:41 AM
  #239
bortous's Avatar
All sorted.
I need part number 311 with the 210 tip.
If I ever take heads off again I'm going to clearance them for 3/8 pushrods.
I have been in contact with LGM racing and development.
How much did you pay for a set of these Manton pushrods?
Old Sep 7, 2019 | 07:01 PM
  #240
JakeFusion's Avatar
Super Hulk Smash
If you get the Manton Series 4 for Guideplate use, they are designed to rub against something. So even if you make contact with the head, it won't hurt them. And will probably clearance the head a little while they are at it.
