Ls2 408 stroker
Old Sep 8, 2019 | 05:59 AM
  #241
Launch's Avatar
OP, how old are your coils? LS coils begin to deteriorate with age and can't spark adequately at high cylinder pressures over high 6k rpms and it won't show up as a misfire or anything. You will just be down on power and not think the coils are faulty. You need to swap on a NEW set of oem delco coils and re dyno it before opening up the engine looking for other issues. The stronger pushrods are a good idea, do those for sure. And check all your ignition wires for ohms resistance. If any are high, replace.
Also, what size are your headers? That combo needs 1 7/8 with 3.5" collectors minimum to make good power. If I were buying new I'd go 2" primary.
Old Sep 8, 2019 | 06:17 AM
  #242
bortous's Avatar
The coils are are 14 years old. Good thinking with that.
Ignition wires are brand new.
Headers are 17/8 with dual 3 inch collectors.
Old Sep 9, 2019 | 06:55 AM
  #243
lazerlemonta's Avatar
Originally Posted by JakeFusion
If you get the Manton Series 4 for Guideplate use, they are designed to rub against something. So even if you make contact with the head, it won't hurt them. And will probably clearance the head a little while they are at it.
Wouldnt that side load if contact is made stress the rocker cup or pull the push rod out of the center of the lifter?
Old Sep 9, 2019 | 10:13 AM
  #244
bortous's Avatar
Thought to update everyone.
First of all I spoke with Manton, and told them the issue I have been having and they are also certain it is the pushrods.
A trend 5/16 with an .80 wall will certainly not handle 500lb of open spring pressure, the heavier rockers and head valves plus high rpm capability.
Not surprised power is rolling over at 6000rpm.
This is the only explanation that is making sense to me.
Engine was only making 340rwkw when spring pressures were increased. It's an improvement from 325rwkw but power is still falling off after 6000rpm.
As others have said, the Manton pushrod is around 150% stiffer compared to the one that I have so it will be interesting to see how it turns out once installed.
If this still doesn't fix it I will need to go back to the standard rocker ratio and then I will most likely need different length pushrods again....
However I am confident the issue is the pushrods but we will see what happens.
Thanks everyone for your help and suggestions.
Old Sep 9, 2019 | 11:39 AM
  #245
JakeFusion's Avatar
Super Hulk Smash
Pushrods flex at speed anyway. That's the point of having a stiffer pushrod. If they don't touch when you cycle it over by hand, that doesn't mean they don't touch at 7000 RPM. It's why harmonics are so important so you don't loft the lifters or pole vault the pushrods.
So no, I don't think the contact would do that, but I haven't spintron tested to see what would happen. Though remember, there's a couple of hundred pounds of spring pressure keeping it all together.
Ideally, you don't want any side load on the pushrod. But if it were to kiss from any instability, it shouldn't hurt anything. One of the benefits of a melonite hardened pushrod.
Old Sep 9, 2019 | 11:40 AM
  #246
KCS's Avatar
KCS
Moderator
Old Sep 9, 2019 | 07:44 PM
  #247
Tuskyz28's Avatar
Old Sep 10, 2019 | 08:02 AM
  #248
psicko's Avatar
I honestly think you should get your tuner to try something like this, just to eliminate the possibility of a dropped cylinder.:
Old Sep 10, 2019 | 10:59 AM
  #249
cmysix's Avatar
What length PR do you need? I have a couple of sets of .105 .120 wall 5/16. And got a set of 3/8. .80. 7.525
Old Sep 10, 2019 | 11:32 AM
  #250
bortous's Avatar
Hey man,
I need 7.800 length.
3/8 will not fit.
I have already ordered 11/32 .120 wall dual tapered pushrods from Manton.
I wish I could fit 3/8.
If heads ever come off I will do the clearancing for the 3/8 for sure.
Old Sep 11, 2019 | 10:47 AM
  #251
bortous's Avatar
Does anyone know the tensile strength of a Trend 5/16 .80 wall pushrod vs a Manton 11/32 .120 wall series 3?
Old Sep 11, 2019 | 10:57 AM
  #252
Darth_V8r's Avatar
Moderator
Tensile strength is misleading. It is load divided by cross section area.
A 1/2 inch bar and a 2 inch bar both have a tensile strength of 100,000 psi. The half inch bar max load is about 19,600 lbs. the 2 inch bar max load is 314,000 lbs.
That is why you need to look at load and stiffness, not tensile strength.
Old Sep 11, 2019 | 11:19 AM
  #253
bortous's Avatar
Thanks for that Darth
I noticed you have the series 5 pushrods. Do you know the figures for these on top of your head?
I was thinking of getting this series but LGM said they are overkill for my application and the series 3 will be more than enough.
Damn, they are expensive pushrods though but they are one of the best from what I have read.
Do you think the series 3 will be quite capable?
Old Sep 11, 2019 | 11:33 AM
  #254
Darth_V8r's Avatar
Moderator
S3 will be fine. Iirc tensile of s5 is 180k. Grain of salt with that number though.
Old Sep 11, 2019 | 11:43 AM
  #255
bortous's Avatar
Ok cool.
Old Sep 11, 2019 | 12:45 PM
  #256
Ls7colorado's Avatar
inn for results
Old Sep 11, 2019 | 01:55 PM
  #257
Darth_V8r's Avatar
Moderator
Just a question but did yall ever test to rule out a dead cylinder?
Old Sep 11, 2019 | 09:28 PM
  #258
bortous's Avatar
This was the first thing that was tested.
All is good.
It is definitely not a dead cylinder.
Still quite confident it's the pushrods causing the issues as they are the weakest link in my valvetrain.
Old Sep 11, 2019 | 09:30 PM
  #259
bortous's Avatar
Found this article too which may be of interest to some:
http://www.sbintl.com/tech_library/a...erformance.pdf
Old Sep 16, 2019 | 10:36 AM
  #260
bortous's Avatar
Does anyone know the stiffness difference between an 11/32 .120 wall pushrod in the series 300 and series 500 from Manton?
As many of you know I have the series 300 ordered so just curious on the difference.
