Ls2 408 stroker
Old Oct 20, 2019 | 04:17 PM
  #441
Darth_V8r's Avatar
Moderator
Originally Posted by Launch
Below is specs of a 243/250 comp hydraulic roller I bought a few years ago and I haven't used it. 13021R / 13164R
HR 108.0 It looks like new with no wear.The previous owner (aussie) said it made 500rwhp in a n/a stock stroke ls3. Not sure what heads he had and he pulled it out to go boost. I'm going to try this in my ls2/ls7 heads build, but run it as a solid and see what happens. It's very similar specs to the old T-rex but not on xe-r lobes. And I have 1.8 rockers which will bring the lift to around .650/.640 after lash
INTAKE ..
XTREME ENERGY™ LSL HYDRAULIC ROLLERS FOR LS1
The LSL Series has been designed with enhanced characteristics from our latest professional drag racing profiles.
These have excellent ramp quickness but are designed in a way to improve stability over other designs with such short seat timing. The increased lift works well with the latest Gen III and LS cylinder head port designs by providing excellent area above 1/2" valve lift.
..................@050 ............................ ...1.7 / 1.8 rockers
13021 - 293 243 166 .367 .105 .089 .624 / .661
EXHAUST ..
XTREME ENERGY™ LXL HYDRAULIC ROLLERS FOR LS1
The LXL Series is based off the popular LSL profiles but are optimized with lower acceleration and a softer closing ramp for less valve train noise and better stability with higher (1.8:1+) ratio rocker arms. These profiles are an excellent choice on the exhaust when used with an LSL intake and perform well for both the intake and exhaust when used in either LS7 or other high ratio applications. These also are a great choice for road race type engines that require extended use at high engine speeds.
.................@050 ............................ ....1.7 / 1.8 rockers
13164 - 302 250 170 .362 .117 .101 .615 / .652
It will run about like a 238/245 with solids set at zero lash, fwiw.
Old Oct 20, 2019 | 06:55 PM
  #442
Launch's Avatar
Originally Posted by bortous
Nice looking build man.
Nice and clean.
I want to make love to that intake port.
If you are running a solid cam don't skimp on lifters.
Buy the best ones you can afford.
Cam motion and another member on here told me the same thing.
Needle bearing lifters can fail suddenly.
Which is why Buy the best ones you can.
If you have the money go bushed.
I know I should just fork out for the best that's why I haven't decided. I'm hearing very positive feedback about BAM lifters from some other forums. The owner used to r&d for crane and left and made his own brand.
Old Oct 21, 2019 | 02:25 AM
  #443
bortous's Avatar
Haven't heard anything about them.
Personally I would not go for a lifter with a no name brand.
The brands that have been around for a long time like Morel, Isky, Crane, are what I would stick to.
If you read my other post, crow cams from Australia recommended a bushed lifter which they claim was made by Morel in Japan.
This was only rated to 225lb of seat pressure and 550lb open pressure and I could only use 5w40 oil.
I found this a strange specification for a solid lifter and didn't go ahead with it.
Old Oct 22, 2019 | 11:17 PM
  #444
Launch's Avatar
No the BAM are a very good quality made in USA lifter and gaining a very good reputation for themselves. Lots of hardcore drag racers are using them now even here in OZ. Apparently they are even holding up better than some of the good brand names and even their sizing is more spot on to use with stock lifter bores compared to some other brands. They aren't cheap. 2k to get here in OZ for their best series of lifter which is bushed and pressure fed, but rather than a bronze bushing that wears they have a proprietary steel with coating so it's basically rolling steel on steel with pressurised oil so they last a very long time given if all else in the valve train is as it should be.
Because of the cost over here for bushed lifters and I have seen so many people now that have had the cheaper needle bearing solid lifters just not hold up as long as they'd like with street usage, I have just about decided to keep this LS2 build I'm doing as a hydraulic roller and focus on extracting power elsewhere even single turbo if I want to get serious. Single turbo LS's are turning 8k rpm with hydraulic lifters. Usually running Johnson lifters but some even are still on the oem lifters or oem gm LS7 lifters and turning that rpm.
There's no doubt I prefer a solid roller set up but due to our aussie prices lately and I dislike settling for lesser quality (cheaper) parts, I know I can put that money to better use elsewhere on the car. I might still change my mind and order a set of solid lifters but at this stage that is what I've decided.
Old Oct 22, 2019 | 11:22 PM
  #445
Launch's Avatar
Darth did you have the drop in solid lifters in your 346 and they were good to you? The solid lifters that use the factory plastic buckets. I recall reading something in one of my searches but I can't remember now if it was you or someone else. That is my only other thought, I try those and see how they work out as they are currently 1/3rd of the price here on special versus good tie bar solid lifters. And 1/4 of the price of good bushed tie bar solid lifters.
Old Oct 23, 2019 | 12:14 AM
  #446
bortous's Avatar
Do you know any info on the solid lifters crow cams now uses?
Old Oct 23, 2019 | 01:13 AM
  #447
Mickyinks's Avatar
I havnt heard of any failures with crower hippo solid lifters, they run needle bearings. If running on the street its not like youll be running 300-400 on the seat and 800+ open
Old Oct 23, 2019 | 02:48 AM
  #448
bortous's Avatar
You misunderstood.
There is a company here in Australia called crow cams.
Crower is different.
It's the ones from crow I was asking about.
I can't find any info about them at all.
Old Oct 23, 2019 | 02:55 AM
  #449
Mickyinks's Avatar
You misunderstood.
Realised that, just stating the crowers with needle bearings are good due to few comments about needle bearings and bushed lifters.
Crowers are $1300 here in Aus Bortous, Not much talk about the crow solids
Old Oct 23, 2019 | 03:01 AM
  #450
bortous's Avatar
Ah yes all good.
Old Oct 23, 2019 | 06:08 AM
  #451
Darth_V8r's Avatar
Moderator
Yes I did. I did not have any issues at all. Resold them. As far as I know they are still running good.
Old Oct 23, 2019 | 08:22 AM
  #452
Launch's Avatar
Apparently they're repackaged Morels.
Old Oct 23, 2019 | 08:31 AM
  #453
bortous's Avatar
No not anymore.
Crow stopped using them.
The ones left for sale on the internet is their older stock which are Morels.
Old Oct 23, 2019 | 08:42 AM
  #454
Launch's Avatar
I think you have just about convinced me to buy those and see how they do. Currently $480 here with ebay discount. I can buy almost 3 sets of those for the price of one set of good tie bar pressure fed lifters.
Old Oct 23, 2019 | 08:44 AM
  #455
Launch's Avatar
No not anymore.
I have no idea where they're getting them from now.
Old Oct 23, 2019 | 10:30 AM
  #456
AINT SKEERED's Avatar
KIP The owner of Cam Motion runs them in his personal daily driver vette
Old Oct 23, 2019 | 10:42 AM
  #457
bortous's Avatar
I know but kip is also running a mild camshaft in his car.
Same rpm range as stock camshaft really.
But still these low lash lobes but be quite smooth and stable to be this reliable.
Old Oct 23, 2019 | 12:05 PM
  #458
Still.as aggressive as hydraulic roller. Which he is asking about using the lifters on
Old Oct 23, 2019 | 12:29 PM
  #459
bortous's Avatar
Indeed
Old Oct 23, 2019 | 12:57 PM
  #460
Darth_V8r's Avatar
Moderator
Full disclosure. I ordered the tie bar, pressure fed lifters for my next cam swap, but my cam is aggressive AF
