Ls2 408 stroker
It's definitely not the injectors as they were removed and cleaned and tested good.
I will update again once I have more information.
It's driving me crazy.
Will mention it
Looks like that on my torque curve
If anything I'd go with a thinner gasket and get quench as close to the .030" range as possible.
But going to a thicker gasket is just a band-aid to cover what is likely a bigger problem.
KW
After a conversation with my tuner the issue is valvetrain instability.
He checked the valvetrain and the springs cannot handle the lift and the valve train is floating so we need to lower the lift.
The valves are staying open at high rpm and causing the power loss.
We feel it might be because of the heavy pro street rockers.
This is also causing the converter to act a lot tighter because engine is way down on torque too.
So I might have to change out the rockers and go back to a standard 1.71 ratio.
However the PAC1209X spring should be able to control them because they are rated to .750 lift.
I said this and I was told that's what it can handle as a maximum value but it depends on combination.
Open pressure is at 450lb and seat pressure is at 170lb
So tomorrow I should know for sure what the culprit is causing these issues.
He is also having a spring tester delivered from one of his colleagues to measure lift.
You never know the springs may be faulty.
I also looked at the dyno sheet today and with the old 236/244 camshaft, engine was actually making 510rwhp and 900Nm torque.
For some reason I am no longer pissed off.
They are already a hard spring,
If I get a stouter spring does this mean my open pressure and seat pressure will be higher too?
Depending on the spring, Higher open pressures don't always mean much higher closed (rest) pressures
