LS7 into a LS3 hole
Old Aug 11, 2019 | 09:43 PM
Try2pass's Avatar
Default LS7 into a LS3 hole
I have a LS3 in my 1980 corvette. Can I just drop a LS7 in there if I put an oil pan on it? Same everything else? Like serpentine belt set up and mounts etc.
Old Aug 11, 2019 | 09:46 PM
MY_2K_Z's Avatar
Ls7 is drysump
Old Aug 11, 2019 | 09:58 PM
QwkTrip's Avatar
Yeah, pretty much drops in after you do a wet sump conversion.. You might need a custom damper to obtain the pulley spacing you need. The heads are a little bit taller so watch clearance around the coils and brackets. Location of header collectors will spread out just a tad too.
All in all there isn't a lot of difference between a well built LS3 stroker and a well built LS7. I thought the LS7 was kind of a waste of money in hindsight. The LS7 was expensive!
Old Aug 12, 2019 | 09:05 AM
LSleeper1500's Avatar
You have a great starting point with having the LS3 already. You would save money by throwing a cam in it and maybe even a basic CNC job on the heads and make some good power instead of the price of a LS7 and then to converter it to wet sump. With a good combo you could make 470-500 rwhp with the LS3. Tons of variables of course. Stick with what you got!
Old Aug 13, 2019 | 02:12 PM
KW Baraka's Avatar
As mentioned, if you go LS7, you would need a new crank and drill a oil dip-stick hole to convert it to a wet-sump set-up.
And good H/C set-up will wake up your LS3 to the tune of 80-100 HP at the wheels.
Jus' sayin'.....
KW
Old Aug 13, 2019 | 04:06 PM
Smokey B's Avatar
Post#4....ls7 isn't needed unless u just wanna be able to say you've got a 427. 650 @ the crank isn't relitively out of this world with 376 cubic inches.
Old Aug 13, 2019 | 07:19 PM
Darth_V8r's Avatar
Moderator
The gpi intake tests hit damn near 700 crank on a couple of their tests on a 376. Big cam high rpm but they cleared 650 handily on several intakes.
Old Aug 13, 2019 | 11:49 PM
Smokey B's Avatar
Brother didn't even think about that. Was thinking of a general reference. 11.5 and or about a 240 ish cam with a 376.
Old Aug 14, 2019 | 01:41 AM
Smokey B's Avatar
Example....way before.....
https://www.yellowbullet.com/forum/s...d.php?t=449281
Old Aug 14, 2019 | 03:04 AM
Darth_V8r's Avatar
Moderator
Gotcha. But I was agreeing with you and backing up that it can and has been done
Old Aug 14, 2019 | 09:45 AM
Smokey B's Avatar
I know just wanted to get you the simple build from 3pedals ... everyone else also.
