New stroker has arrived!
Whats your tire height?
If they nail the efficiency at the top end you can have your cake and eat it too.
The same converter before we tightened it up a hair was going 7600 at 130, but was hitting harder off the line. The car was trying to turn over backward with more power from the 4” stroke.
Once you have a dyno sheet you share it with FTI and they can match your converter.
They can definitely get better on efficiency which would let you keep your 4.30’s or maybe even go to 4.56’s someday. Flashing just past torque peak is what you want which definitely sounds like it’ll be around 6000 rpm especially with a bigger cam.
You're close to transforming this thing. Exciting man!
