New stroker has arrived!
Old Sep 2, 2019 | 10:22 AM
  #101
AINT SKEERED's Avatar
Originally Posted by BigDaddy97
Ok we will install the rockers but will need different springs as the trick flow springs are only rated to .650. My builder was nervous about using the YT rockers and adding weight over the valve verses my stock rockers at 7500 rpm. I have no problem going to 7600 on the shift. I went from bias ply to drag radials last year and picked up 1/10.
Converter restall for this motor and the rocker arms will help.
I use solid roller but pac1209x springs with yt roller rockers for stable 7800 rpm shifts
Also note shift extensions on shift. If you falling more than 1000 rpm on shifts it will lay over
Old Sep 2, 2019 | 10:25 AM
  #102
BigDaddy97's Avatar
What springs would you recommend for me? The lift will be .660 with the 1.8 rockers.
Old Sep 2, 2019 | 11:00 AM
  #103
Darth_V8r's Avatar
Moderator
What are your pushrods?
Old Sep 2, 2019 | 11:18 AM
  #104
BigDaddy97's Avatar
Trend 7.8 length, 3.8 diameter, .120 wall
Old Sep 2, 2019 | 12:07 PM
  #105
Im not absolutely sure ,btr or Texas speed had some good to 675 lift I believe.
Old Sep 2, 2019 | 12:38 PM
  #106
Darth_V8r's Avatar
Moderator
I would run pac 1209
Old Sep 2, 2019 | 12:53 PM
  #107
I see turbo guys run them with hydraulic cams so they should work well here as well.
Old Sep 2, 2019 | 01:28 PM
  #108
BigDaddy97's Avatar
ok thanks fellas
Old Sep 2, 2019 | 04:21 PM
  #109
I think it's minimal gains though.
Converter would be my first choice
Old Sep 4, 2019 | 08:56 PM
  #110
Smokey B's Avatar
^^^^^^^^^^^^^^^ 2nd that opinion
Old Sep 5, 2019 | 11:38 AM
  #111
BigDaddy97's Avatar
I just got off the phone with FTI and I'm very surprised at the answer i got. He wants to restall the converter for 6200.
Old Sep 5, 2019 | 11:53 AM
  #112
6200?? That's just about NO stall! LOL Slip-slidin' away....
Old Sep 5, 2019 | 11:57 AM
  #113
BigDaddy97's Avatar
No kidding that is what he said. They just redid the stall on my team mate's truck to 5800. His et dropped from 10.34 to 10.15.
Old Sep 5, 2019 | 12:00 PM
  #114
Hey whatever floats your hydroplane..... and WORKS!
Old Sep 5, 2019 | 12:07 PM
  #115
BigDaddy97's Avatar
I'm a little nervous about that big of a jump but on the other hand the restall is free. Screw it I'm gonna do it.
Old Sep 5, 2019 | 12:31 PM
  #116
I'm a little nervous about that big of a jump but on the other hand he restall is free. Screw it I'm gonna do it.
My 8" they did on my 6.0 went 6200 on the brake but still drove great on hwy cruises.
My 8" I have now with the 427 flashes 5300 but haven't tried the brake yet. I'd guess it's close to 6000. With that glide I wouldn't be worried about it.
Old Sep 5, 2019 | 01:41 PM
  #117
spanks13's Avatar
I’m not surprised at all. You’re going to pick up a fuckton.
Ask for the most torque multiplication you can get off the line with the most efficiency at the finish line and 6200 stall will work great. Shift around 7500 maybe a little higher.
It’ll fall into the converter on the shift and pull like a ****.
I’ve had great luck with a mechanical diode vs a sprag at that power level with a trans brake. Do not go spragless.
With a powerglide the magic is in the converter.
Old Sep 5, 2019 | 02:31 PM
  #118
lazerlemonta's Avatar
LOL nothing like a CVT transmission. That thing is going to just pull hard as fu** from the hit to the end. You may end up pulling a little gear after all hello 9s
Old Sep 5, 2019 | 05:25 PM
  #119
BigDaddy97's Avatar
I have no doubt between converter and cam upgrades that i will have to back the gear down to 4.10's.
Old Sep 5, 2019 | 07:02 PM
  #120
spanks13's Avatar
I’m going 132 mph at ~7000 rpm with 4.56’s and a 29” tall tire.
Whats your tire height?
If they nail the efficiency at the top end you can have your cake and eat it too.
The same converter before we tightened it up a hair was going 7600 at 130, but was hitting harder off the line. The car was trying to turn over backward with more power from the 4” stroke.
