Projekt Lazarus - Numbers Posted!!
Pushrods are all coming in 6.6xx. Very short. My old ones were 8.1xx. I had measured the difference in cup height out of curiosity before installing, and the Isky's are 1.4xx taller. The cup is actually above the link bar on the lifters I bought. Seems strange maybe, but I'm really glad. All things being equal, a shorter column is stiffer than a longer column. It's actually really good for valvetrain stability. Going to remeasure tonight and confirm, and then order.
Also, for anyone interested -- with the adjustable rockers, many will think the way to do it is to center the adjuster and then measure. What I'm doing is maxing out the adjuster so the cup rests against the lifter body. I'll then order the pushrods .010 short. When I install, I should only have to move the adjuster in about .010 to find zero lash. This way, if an adjuster does come loose, the worst that'll happen is I'll have .025 lash like a regular full-sausage solid roller
Looks good though Darth.
Are you getting yours from Manton?
I'll even play mental games like "Ok, if I set this .025 smaller, I should see .045 at the valve tip" and verify that's what happens. I even rechecked wipe, although that wasn't necessary at all. I just like knowing that it's where it's supposed to be after what happened.
I have 8.200 in mine. If I shave the heads any more, my intakes are gonna be to long. I have extra room im exhaust due to less valve lift. Those 8.1?? Happen to be closer to 8.150 or 8.175?
Post some progress shots too.
I like viewing these photos.
Trans AM with a ton of mods and being the name Darth_V8r I'm gonna say it's black.
of the car
