Ls3 c6 build questions
Old Jan 5, 2020 | 07:42 AM
  #81
ddnspider's Avatar
Go BTR dual springs with ti retainers. Hardened or chromeoly 3/8 pushrods are fine. Everything else looks good. New ls2 chain and oil pump too.
Old Jan 5, 2020 | 07:48 AM
  #82
shelbysguns's Avatar
Oh duh forgot that.
Ls2 chain and stocker pump? Or melling?
Itll also get a new water pump (not electric), and all new gaskets.
Did @lazerlemonta say I needed a new balancer? Just oem replacment or sfi/whatever?
Seeing ati at about $400 and summit at about $200. Assuming the powerbond is right out as its just an oem replacement
Old Jan 5, 2020 | 07:56 AM
  #83
How do we feel about the btr stage 3 cam? Seems fairly close to the titan 3. Specs below for reference.
Titan 3
Duration at .050": 227/237 - 113 Lobe Center Angle with a 109.5 Intake Centerline
Lift with 1.7 Rocker Arm Ratio: .621"/.604
Btr stage 3
Specs: 229/244 .615"/.595" 113+4
Just asking as the price at 719 for the kit with btr springs and ti retainers is appealing. Though it is 5/16 pushrods, might email them to see if theyd swap.
If its not as good no problem. Not going to let a few hundred dollars cause me a headache.
Old Jan 5, 2020 | 08:17 AM
  #84
ddnspider's Avatar
BTR cam will give you more chop. You may just call BTR and ask them to do an entire package deal and let them spec pushrods, timing chain, oil pump, etc.
Old Jan 5, 2020 | 08:18 AM
  #85
Not a bad idea but thats what you guys are for 😂
Might do that when im home.
Old Jan 5, 2020 | 09:26 AM
  #86
Darth_V8r's Avatar
Moderator
Depends on where you want your power. If you are just trolling the streets I would stick with T3. If you want more top end the BTR. But then you may as well get the Titan king like cam motion posted earlier. They do full kit specs also.
Old Jan 5, 2020 | 10:22 AM
  #87
Curious what the real difference will be here. Peak moving up to 7k? Will the bottom end of the rpm be weaker? Just noodling some things.
Old Jan 5, 2020 | 10:57 AM
  #88
ddnspider's Avatar
With a properly spec'd torque converter and tune it won't matter.
Old Jan 5, 2020 | 11:02 AM
  #89
So whats the con then? Like I said I plan to cam the car and dyno tune it then buy a convertor that works best with the curve.
Old Jan 5, 2020 | 11:15 AM
  #90
ddnspider's Avatar
Higher power band will make the bottom end of the RPM range softer, but a torque converter that's sized properly will mask it. More overlap, as in bigger cam, also don't idle and drive as well, but again a stalled auto and a good tune will also help that.
Old Jan 5, 2020 | 11:18 AM
  #91
bortous's Avatar
If you are wanting to run 10 sec down the 1/4 mile you will at least need a stage 3 camshaft.
Either the 233/250 113lsa +5 from Brian Tooley or the titan 4 from cam motion.
​​​​​​you will require gearing and other supporting mods too for this to work well.
Old Jan 5, 2020 | 11:22 AM
  #92
Higher power band will make the bottom end of the RPM range softer, but a torque converter that's sized properly will mask it. More overlap, as in bigger cam, also don't idle and drive as well, but again a stalled auto and a good time will also help that.
Interesting. Curious as to @Darth_V8rs take on it.
Old Jan 5, 2020 | 01:30 PM
  #93
Darth_V8r's Avatar
Moderator
Spider is telling you right. Eventually it comes down to preference. A slightly tighter converter and slightly smaller cam vs larger cam and looser converter. If you do not plan to rev into the 7's, I would truly stick to the smaller cams.
But if you want the bigger cam you can use a looser stall to tame it.
Old Jan 5, 2020 | 10:33 PM
  #94
What else would have to change to rev over 7k?
Old Jan 6, 2020 | 06:18 AM
  #95
ddnspider's Avatar
If you get the valvetrain right, nothing.
Old Jan 6, 2020 | 07:05 AM
  #96
Darth_V8r's Avatar
Moderator
Pretty much nothing else. You've picked out good lifters. Get good pushrods, do not overspring, and you should be in great shape on any of the cam options in this thread.
Old Jan 6, 2020 | 07:23 AM
  #97
lazerlemonta's Avatar
This is a bull **** statement lol I went mid 10s stock cam/heads...... There is an auto that bested me by a few thousandths as well stock cam. These cars work well when you put some effort in to make them accelerate..... Spend the $400 and buy the ATI or look on the forums/ facebook etc for a used one.
Old Jan 6, 2020 | 08:33 AM
  #98
bortous's Avatar
Let me get this straight, are you saying a stock cam and stock headed LS3 can run 10 sec down the 1/4 mile?
and this is without forced induction correct?
Old Jan 6, 2020 | 08:49 AM
  #99
ddnspider's Avatar
...and here we go!
Old Jan 6, 2020 | 08:53 AM
  #100
Yes 100% stock cam and stock heads. NA.... Why do you think I am so pissed off at my head cam set up lol I have been 10.62 at 134.8 with it....
I went 11.0 with 100% stock exhaust too lol
