Which Cathedral Head is best?
Old Jan 21, 2020 | 07:50 AM
  #141
AINT SKEERED's Avatar
Originally Posted by bortous
Good flow numbers.
What cc are your intake runners?
That test is on a 4.080 bore too.
Smaller bore will have less flow.
272 cc runners.
I know the thread is about cathedral ports.
if I was doing a hydraulic cam I'd probably go with a good cathedral port shifting 7000 or less. But solid roller over 408, prefer a ls3 or ls7 head
Old Jan 21, 2020 | 07:54 AM
  #142
bortous's Avatar
Originally Posted by AINT SKEERED
272 cc runners.
Cool bananas.
Old Jan 21, 2020 | 08:37 AM
  #143
Darth_V8r's Avatar
Moderator
Me and skeered done gone back and forth a lot. His car does great and I think would do more greater with ls7s
Old Jan 21, 2020 | 08:40 AM
  #144
I'd like them, just gonna see what I can get with them ls3's first.
Old Jan 23, 2020 | 10:40 AM
  #145
bortous's Avatar
Has anyone used or know of anyone that has used the MAST 295cc LS1 cathedral port head?
It has peak flow of 410CFM at .750 lift.
Would they be any good at a 295cc intake runner?
They do require a 4.125+ to fit.
https://www.mastmotorsports.com/coll...oducts/ls1-295
Old Jan 23, 2020 | 10:53 AM
  #146
Smokey B's Avatar
Never...been wanting to see them used...
Old Jan 23, 2020 | 10:54 AM
  #147
bortous's Avatar
That's some very serious flow for a cathedral port head though.
Old Jan 23, 2020 | 11:03 AM
  #148
01CamaroSSTx's Avatar
Can't outflow the high end LS7's though
Old Jan 23, 2020 | 11:32 AM
  #149
bortous's Avatar
Depends on what you mean.
The highest flowing head I have seen is a custom LS7 style head that flows 500cfm but requires custom parts.
The other LS7 I know is from Mamo who uses a trickflow casting and does his magic on it.
This flows 410cfm from a 265cc runner.
I'm betting though that the cathedral head listed will be stronger in the low and mid range.
Old Jan 23, 2020 | 11:43 AM
  #150
Darth_V8r's Avatar
Moderator
Three most important items on head performance are airspeed, airspeed, and airspeed. 295 runner vs a 265, all else being equal, would benefit higher rpm not midrange
Old Jan 23, 2020 | 11:53 AM
  #151
Tuskyz28's Avatar
In my Cookbook thread Bortues the LS7 heads trap the highest MPH out of 30 combos minimum i have recoreded....
Old Jan 23, 2020 | 11:54 AM
  #152
bortous's Avatar
Darth, if you had two identical heads.
Both were 295cc.
One was LS7 one was cathedral.
Both flowed the same peak CFM at the same lift.
Which head would have better performance in the low and mid range rpm band?
  #153
bortous's Avatar
i know that but still I'm curious how this head would do.
Old Jan 23, 2020 | 12:21 PM
  #154
Darth_V8r's Avatar
Moderator
Both were 295cc.
Ls7 style for the raised runners
Edit - bit of an impossible question. Same port volume ls7 will pretty much always outflow same volume cathedral. Often smaller ls7 ports will outflow larger cathedrals. Air speeds on the ls7 are just better all around due to short side radius
Old Jan 23, 2020 | 12:25 PM
  #155
I'm thinking the cathedral would perform better in low-mid and the square ports still will make more hp.
Old Jan 23, 2020 | 12:29 PM
  #156
bortous's Avatar
That's what I'm thinking too.
The LS7 style head would make more HP for sure but I also think at a higher rpm.
Old Jan 23, 2020 | 12:35 PM
  #157
bortous's Avatar
Yep.
Got it.
LS7 for the win.
I look forward to the day I work out which LS7 head to go with.
It's a real head ****.
Old Jan 23, 2020 | 01:25 PM
  #158
Smokey B's Avatar
Brodix ...if you want something special ask for the big spring package which requires Shaft mounted rocker arms with a Thick wall...It has just as much meat as a All Pro, Mast, etc..... 800 each bare and get port work... Roughly $1100.. gets no better... Get the best casting available and have your choice in Porter's.. It has the meat for anything.. your head just have port work to match your combination & RPM
https://www.jegs.com/i/Brodix/158/1178005/10002/-1
Old Jan 23, 2020 | 05:49 PM
  #159
rkupon1's Avatar
Smokey, that link shows them for over 3k bare. Where do you see them for $800?
i got my own bookmarks goin on too...
Old Jan 23, 2020 | 07:06 PM
  #160
Smokey B's Avatar
I always call and ask for heads as cast! There's a part # for both heads.. Normal and the BS package.
​​​​​​I'll never buy with a CNC port...Y? I'm generally kinda on the wild side and know matching the CSA to the RPM and stroke used is the best thing....No reason to send a New CNC head back out...
that's Paying x2...
