Dart SHP Pro Iron 434
Old Jul 29, 2020 | 07:34 AM
  #581
ramairws6's Avatar
Dart all aluminum skirted LS Next Block
Old Jul 29, 2020 | 07:51 AM
  #582
bortous's Avatar
That's a good block.
May I ask how much you paid for it?
I originally wanted to get the aluminium version however the cost was 2.5 times as much compared to the Pro iron Block I have.
I'm curious to see if the block is any cheaper where you are compared to here.
Old Jul 29, 2020 | 08:14 AM
  #583
Double06's Avatar
Coming together going to be an awesome build. When do you think you will have it running?
Old Jul 29, 2020 | 08:24 AM
  #584
bortous's Avatar
Yes it is finally nearing the end now.
I was going to post tomorrow with a small update but seeing as though you have asked now I shall do it for everyone.
Lifters and heads are complete, and it's pushrod time.
Unfortunately those Custom Manton Pushrods I got are way too short to use.
The length I need will have to be at least an 8.500 but I will find out tomorrow for sure what is needed. Needs to measured up correctly.
After this, the engine will finally be installed in the vehicle, the intake manifold, and steam port kit attached and then will be ready for tuning.
There is a chance engine will be fired up this week sometime, if not, definitely next week.
Old Jul 29, 2020 | 10:25 PM
  #585
caviness's Avatar
cool im ready for more pics and see what this thing does
Old Jul 30, 2020 | 06:32 PM
  #586
rkupon1's Avatar
Aftermarket aluminum lsx block>$5,000.00
I paid $5300 for my RHS standard deck block
Old Jul 30, 2020 | 07:52 PM
  #587
And to put this into perspective, I have around $4800 in my Darton sleeved GM block after fitting Katech billet main caps and all machine work. I’ll go aftermarket next go around.
Old Jul 30, 2020 | 09:28 PM
  #588
bortous's Avatar
That's exactly what my builder told me about sleeving.
The expense to do it comes to the same cost as a new block.
Unless you got to have a gm aluminium block, the aftermarket is the way to go.
At $2960 I have a state of the art block that comes with beefy ARP main caps with minimal machining required to get it ready for assembly.
Although this block does require an expensive ARP head bolt kit though.
  #589
bortous's Avatar
Thats expensive.
Down here the price would be even higher.
Old Jul 30, 2020 | 09:39 PM
  #590
bortous's Avatar
Pushrod length needed ended up being an 8.500
3/8 diameter .138 thick wall.
Also with a 210 degree radius tip.
We JUST couldn't use the 8.400 length pushrods from old engine as they came up too short.
They won't be here till next week.
The performance shops down here have been extremely busy and sold out of a lot of parts.
Old Jul 30, 2020 | 09:46 PM
  #591
AINT SKEERED's Avatar
I had head bolts already and now just spent $500.00 for 6bolt stud kit
Old Jul 30, 2020 | 10:01 PM
  #592
98_WS6_M6's Avatar
My aluminum ls next block was under $5k. My ls7 block was $2k lol. To sleeve it was a little over $1000. I got a smoking deal or I would've done an aluminum Ls next for that too. Something cool about a stock gm block imo. I don't know why I like it. Hell my stock aluminum LS1 block is pretty quick too. Darth has a fun setup. Rare gm block is cool af.
Old Jul 30, 2020 | 10:14 PM
  #593
bortous's Avatar
The gm ls7 blocks down here are so expensive at 5k USD for a new one.
We also have readily available the gm c5r block for 6200 usd.
You guys can see why I chose my current block.
Old Jul 31, 2020 | 12:07 AM
  #594
98_WS6_M6's Avatar
For sure. I got lucky.
Old Jul 31, 2020 | 06:37 AM
  #595
Darth_V8r's Avatar
Moderator
Darton wet sleeve was ~2200 plus another 1200 in the finishing machine work such as final hone. Look at it this way. If you already have a block, then the wet sleeves might be a good option.
If you have to buy a block anyway, things get muddier for sure. Or if you have a unicorn block or one with sentimental value - like it came from your dads car or something or you and your brother built it years ago type of thing.
Old Jul 31, 2020 | 07:07 AM
  #596
bortous's Avatar
You guys have it good up there for parts.
Does anyone know how much my block is to get direct from a supplier up there?
Old Jul 31, 2020 | 07:13 AM
  #597
Darth_V8r's Avatar
Moderator
Four koalas and a kangaroo?
Old Jul 31, 2020 | 07:30 AM
  #598
Bort, Jegs shows it for $2822.00...you should be able to see the pricing on the net? No?
Old Jul 31, 2020 | 08:42 AM
  #599
bortous's Avatar
Close.
That plus a dingo.
Old Jul 31, 2020 | 08:45 AM
  #600
bortous's Avatar
It does but i am wanting to know supplied to someone local in the USA.
The postage and import charges are stupid high to come here.
How much is postage to you though?
