The 830HP pump gas 434 that could
Launch if the valve train is on spec. ..800 to 900 lift is Doable.
DragWk set-up. Chris U, I think 🤔 it was did a 440+Cleveland street engine 900+ lift.
3v performance did the cam testing.
😂😹 I'm looking @ 800+ before lash 🤫 vol 2.
830 max lift Street Endurance spring 🤨.
If set up properly spring wear is the only thoughts..... 3 to 5k milage check spring pressure 🤫 if consistent continue.
I probably have close to 2k miles on this setup now and couldn't be happier. I've been to a bunch of carshows and participated in a few shootouts + grudge runs. All in all I really can't complain. Did a fair amount of testing with the transbrake and seems to work pretty good on the street.
What next?
It's still only street tuned so once the weather breaks we plan on doing some chassis dyno runs to find some HP. And since I still have the CID 4" intake I'm also contemplating bumping up to the 4.5" version over the winter. Oh and I've gotta reconnect my shift light. It's impossible to see the integrated one in the Holley 7" Pro dash. Anyway here are a few street passes.
vs a 5.3 swapped Mustang on nitrous (W)
vs a twin turbo swapped Mustang (L)
vs a Turbo T/A (skip to 1:30) (W)
I am sure the forum would love to know vehicle weight and 1/4 mile times/speed to substantiate the posted info. The dyno power shown illustrates enough HP for easy 8.90's in the 1/4@ 3000#.
He runs on the street/grudge, et doesnt matter, just besting the guy next to him by barely enough.
