Trick flow 235 heads
Is the engine stock displacement?
The Car already had the heads on it.
and I’m trying to figure out what could be the CI of the motor. If the heads won’t work with anything under a 4.125 then the possibility of the car being a 416 or bigger is possible right?
I have seen dyno sheets with trickflow and afr 245 heads on engines with smaller bores and they kind of disappoint in the power department. On large bore sized engines they make crazy power.
However Trickflow did tell me the optimum bore size for their 245 head is a 4.155 bore or larger.
AFR say 4.125 but on their testing they used s 4.155 size bore also.
These cylinder heads are not designed as a stock replacement, they can only be used on 6 bolt LSX-based engines with a minimum bore diameter of 4.125 in. Must be used with roller rocker arms.
Could be a 427 LSX
Plenty of TFS headed 40X going low 10s with a man pedal. All be low 10.5s
Just for some salt shaking I have seen ONE 40Xci AFR 230 headed go 10.6s with a 6 speed.
