Stock LS3 & Mast LS7 265cc
Old May 29, 2020 | 02:57 PM
F-Killer's Avatar
Default Stock LS3 & Mast LS7 265cc
I've been searching for days and couldn't find any build or thread that spoke about this, I have a built 408 with mast ls7 265cc heads and now I want to put these heads to my ls3 stock bottom engine w/gt11 cam, has anybody had any PTV clearance issues when using the mast ls7 265cc heads without flycutting the pistons? Are you using 8.150 pushrods with 1.7 ls3 rockers? Which head gasket brand & thickness are you running? Thanks!
Old May 29, 2020 | 03:12 PM
WE TODD DID's Avatar
Just check it.
Old May 29, 2020 | 03:43 PM
F-Killer's Avatar
Of course I will check it but I dont live in the US so I need to order parts in advance, shipping and customs take a lot longer
Old May 29, 2020 | 10:57 PM
bortous's Avatar
What are the specs of that cam?
Old May 30, 2020 | 12:18 PM
MLP00Z28's Avatar
215/231 - .631/.644 - 118.0
Old May 30, 2020 | 12:23 PM
bortous's Avatar
Don't mean to be rude but that is not a good camshaft.
I had it once.
It's soft and torqueless.
Old May 30, 2020 | 12:47 PM
That is a very old Lingenfelter grind. They haven't come out with any thing new in over 10 years.
That wide an LSA will kill off any low end torque, The late IVC of 45.5 doesn't help things either
Old May 30, 2020 | 01:02 PM
bortous's Avatar
That's exactly right.
I had this camshaft in my ls2 with the 243 heads.
I remember first driving it, immediately I noticed the throttle response was way down and the entire torque curve was soft.
The stock camshaft pulled harder the whole way through even though the lingenfelter camshaft made an extra 35hp.
This camshaft lasted about a month or two before I pulled it out.
I have so many bad memories. I have never had a camshaft that worked the way I wanted it too.
This was my first ever camshaft swap.
Old May 30, 2020 | 01:06 PM
I mean, 45 IVC in a street cam?? And 18 degree LSA is for blown engines where boost overcomes lots of silly wrongs, but not NA.
Old May 30, 2020 | 01:29 PM
01CamaroSSTx's Avatar
Those heads would shine in the larger 4.125 bore.
Old Jun 1, 2020 | 12:19 AM
MLP00Z28's Avatar
Those heads are designed for 4.000-4.100 bores, after this you might just get the 285s or 305s
Old Jun 1, 2020 | 07:11 PM
old motorhead's Avatar
Here's the only Lingenfelter cam I'd consider. https://www.lingenfelter.com/product...l#.XtWXEm5Fw5s It would need at least 4 degrees of advance which I'm guessing it doesn't have.
At least that one is done using Comp's LSL lobes and not the stupid high lift LSK lobes that most of their other cams use. I can't believe people still buy that crap.
Old Jun 2, 2020 | 08:40 AM
Darth_V8r's Avatar
Moderator
More often than not, the cam timing, not the head configuration, determines ptv. With an 11-degree valve angle, you'll be in pretty good shape unless the cam is enormous. Increased duration and/or tighter LSA will cause your PTV issues. Not the head selection or the head gasket. That GT11 cam is almost a stock LS7 cam. You won't have any issues. But I agree, it's really not a great option. Something like a 224/233-115+3 will do much better. And still clear your stock pistons by a mile.
Head gasket thickness should not be determined by PTV. Measure the deck height of the pistons. Size your HG to achieve 0.035" net. Example -- if your pistons are .006 out of the hole (above deck), use a .041" HG.
Old Jun 2, 2020 | 06:42 PM
F-Killer's Avatar
Thanks to everybody who replied, I just bought the car which was built back in 2011 and was barely driven since then, I agree the GT11 is an old cam but I didnt buy it, I just purchased this cam 234/242 .626"/.626" 112LSA +4, both Mast and the guy who did me the cam say it will fit under stock non flycut pistons but I will double check it anyways
Old Jun 2, 2020 | 07:41 PM
Darth_V8r's Avatar
Moderator
I think that cam will be ok. Especially with the 11 degree intake valve angle. You gain clearance
Old Jun 2, 2020 | 08:44 PM
F-Killer's Avatar
Thanks a lot, nice explanation in previous post!
