Texas speed and performance
Old Jun 5, 2020 | 01:53 PM
ksLSX316's Avatar
With all these replies does anyone know if an LS1 head or even the 5.3 head can have the valves resized to 2.02/1.90 like old school heads for better flow? I understand that if they can it will definitely change the combustion chamber sizes.
Old Jun 5, 2020 | 04:27 PM
01CamaroSSTx's Avatar
Well not sure about the 1.90 exh. valve and I'm thinking a typo there but yes you can have the seats machined/replaced to accept 2.05 and 1.60 valves.
Old Jun 5, 2020 | 05:02 PM
ksLSX316's Avatar
Yes I screwed up. It’s 2.02/1.60 not 90. I have looked and looked and couldn’t find anything on it other than a few aftermarket companies offering the 2.0/1.55 I believe it was, but not 2.02/1.60.
Old Jun 5, 2020 | 05:13 PM
Yeah there's a thread I read on here about someone who had some 241's done up with 2.05's and 1.60's. I've also cam across those sizes on LS valves searching for aftermarket such as Manley and Ferrea valves.
Old Jun 5, 2020 | 07:01 PM
ksLSX316's Avatar
that’s good to know. I have 2 options 3 really if I use the engine that’s already in the car. Either a 6.0 408 or a 5.3 383 I have 3 sets of 5.3 heads a set of ls1 heads off of a 98 Ta and the 6.0 heads as that’s complete. Really thinking of this trade doesn’t go through just throwing everything into the 5.3 in my trailblazer and selling it to buy an SS or a GTO. Then building my high horsepower N/A motor with room to grow in case I ever do decide to go induction.
Old Jun 6, 2020 | 08:49 AM
Given those options I'd take the 6.0 but to reach 600 at the wheels is a tall order. You'd be best to stroke it with forged internals and your going to need a lot of supporting mods and a power adder. My 01 has an LSX 427 has a cold AC and gets 12-14 mpg on the highway but it doesn't have 600 hp NA at the back tire. Not really sure what it can make as the last time my tuner seen the car was nearly four years ago and it was having a fueling issue trying to get to WOT. It did however make 490 ft lbs of torque and 475 hp at 4000 rpm on a Mustang dyno. Changes have been made and looking forward to seeing what its got but still don't think I'll see 600 hp NA without a power adder.
Old Jun 7, 2020 | 05:41 PM
ksLSX316's Avatar
That’s why I wanna leave room to add a turbo, or supercharger. If I go the 6.0 route I will definitely go 408 with forged internals.
Old Jun 13, 2020 | 03:33 PM
BigDaddy97's Avatar
Originally Posted by ksLSX316
How long have you been running the setup 8k RPM is impressive, is the 8k just on the track or have you ran it at this RPM long term? Is this just a track car or a daily also? Reason I’m asking about daily or track only is I’m wondering vehicle weight, basically anything that’s gonna cause extra stress on the motor and components, for durability Purposes.
Made many passes in the 7500 to 8k range. Drive it on the street occasionally but not a daily driver.
Old Jun 15, 2020 | 06:44 PM
KW Baraka's Avatar
…..I know TSP is a great company people use their heads and cams all the time, but has anyone ever used their other parts cranks, rods, pistons?......
My 429ci LS3 from TSP has about 46K miles over the last 5 years. No issues to date.
KW
Old Jun 16, 2020 | 04:56 AM
Jimbo1367's Avatar
KW
have you had the engine out a pan off to look at the bottom end yet for any signs of excessive wear?
Old Jun 16, 2020 | 09:09 AM
If its not broke don't fix it and if you have excessive wear your going to know...
