ZL1 with LS7 heads issue
Contemplating buying a 13-15 ZL1. I was wondering did the LS7 built during this time have the same valve drop/head issue that the 2006-2010 Corvette Z06 with the LS7 had? Or did GM finally fix this issue?
I've heard some horror stories of the Z06's dropping a valve and needing engine replacement.
Thanks
The Z28 is 300-500 lbs less than the ZL1, and has much bigger brakes, it has some aero bits for helping it stick in the corners, the suspension is much better for cornering, and there's a bunch of other small changes to make it handle better. The idea is that it's supposed to be ready for an HDPE at a road course straight from the factory.
