johnson-st2126lsr-short-travel-slow-leak-down-race lifter with axle oiling
Short travel lifters are much tougher to get set up right, as you need to measure EACH pushrod for correct length, due to the very short travel clearance of the lifter.
You can be up or down quite a bit on length with normal travel lifters, like by .010-.020. Not with these.
I have them in my mild LS3 build. Do you intend on using adjustable rockers? If not, I cut my rails into pairs and shimmed each set of rockers individually to achieve proper preload. I had 6 different lengths made and made them all .010 long to allow for shimming. Your idle oil pressure will be lower than normal due to the axle oiling just FYI
We're using them on some H/C projects.
The stock rails the rockers sit on that run the entire length. I cut them into 4 pairs per head to allow a more precise measuring of preload.
Moderator
Received 1,838 Likes
Overkill is a matter of opinion. I ran them on a LS1 HCI set up until I went for solids. I was very happy with them. Properly set up, they are worth some power over the regular stock lifters.
Short travel lifters are much tougher to get set upright, as you need to measure EACH pushrod for correct length, due to the very short travel clearance of the lifter.
Moderator
Originally Posted by DavidBoren
Wait... there are people that DON'T measure every pushrod, every time?
The following users liked this post:
rkupon1 (09-30-2020)
Isn’t this the lifter GM puts on their COPO engines?
I use the 2116 short travels and they work well. Using the comp pushrod tool I took my measurements and called manton and johnson and discovered that those measurements at gauge length needed to be slightly modified to get my true total. I measure a few exhaust and a few intakes, not all, the ones measured are the same as they should be. I'd be concerned if i had 16 different pushrod lengths. But my heads and block are also flat. Had kelly Bluebaugh make sure of that. They arent very loud at all and rev limiter set to ~7500 no float. Works well and makes great power.
Edit: 2116 "reduced travels"
the tolerances I was given are .040 +- .010
You should measure all the sticks. But, this doesn't mean you should have 5 or 6 different sizes. If the sticks vary .005 or so, the lifter will take it up. If the sticks vary too much, the problem is in the valve lengths. If the valve lengths are within .002-003, one set of sticks should work. Do not experiment with different stick lengths to compensate for a bad valve job. A uniform set of sticks should work.
Key word is should.... The variances can come in many parts of the valvetrain. Cam, lifters, valves and rockers let alone push rod tolerance. I guess if your dealing with LS7 lifters you throw what ever you want in. Short travels you better do your homework and measure each and every one. You basically spend the effort of setting up a solid. Not trying to be argumentative, but a statement of a "uniform set of sticks should work" in my opinion is from someone that has not set up many top ends with precise measuring.
02EBC5Z06 (11-16-2021)
Moderator
I have seen all kinds of crap with the short travels. Basically lazer nailed it. I helped a guy over the phone just this week and he ended up every pushrod was within .003. All 16. Difference is he had a single pattern cam. Intake and exhaust lift were the same. You do the typical .025 lift reduction on the exhaust side, then on short travels that will mean minimum two different sizes. Measure them all and see what you got. Then group them together by close sizes. Figure when you get them back they will be +/- .003, which allows you to match them back up. Typically I see one bastard length either long or short. No idea why but it always seems to happen. Here is how mine went:
![johnson-st2126lsr-short-travel-slow-leak-down-race lifter with axle oiling-photo629.jpg](https://ls1tech.com/forums/attachments/generation-iv-internal-engine/709518d1601900776t-johnson-st2126lsr-short-travel-slow-leak-down-race-lifter-axle-oiling-photo629.jpg)
I checked the 6.686 at least ten times. I ended up ordering a group at 6.642, a group at 6.661, a group at 6.635, and one 6.686.
It is not a matter of what you should get, it is a matter of making damn sure of knowing what you actually need and ordering that.
