TBSS 402 LS2 build
I suspect the use of the LSXRT Intake allows for another ~4* intake duration VS car intake, but that is just a guess.
Looking forward to your build & results. You choose the right Heads and person to spec IMO.
Good Luck
SCR -- 11.75x
DCR - 8.23 assuming a 54 degree ramp rate (that's your duration at 006 minus your duration at 050)
DCR - 8.49 assuming a 48 degree ramp rate.
I'm the crazy guy who would say you could bump your compression to 12.2 and still run 93. And I'm the even crazier guy who would do it, too.
Also, fwiw, I like the low split on that cam. I think you'll have a ton of midrange. Also, nice job on the lift. That'll help a lot too with the extra lobe area.
SCR -- 11.75x
Talked to Tony the other night and got the intake and porting started for that as well as the NW 103. Just waiting on the heads to come in so he can work his magic on them. I believe another 6 weeks out though.
Run the AN line to the vacuum pump uphill as much as possible so any oil sucked up will drain back and not run toward the pump. Do not tap into the valley cover - even with extensive baffling added the thing pumped oil like crazy. Using the oil fill port on the stock valve cover is pretty good. The motion race works baffled breather port looks really trick. They designed it for race week guys doing a ton of miles.
