Summit racing piston problem
Old May 21, 2021 | 01:26 PM
Ranjodh Singh's Avatar
Default Summit racing piston problem
So i order summit racing pistons for my project SUM-32694340651. Its a 4th gen 6.0 that needed machine work so we decided to go with 4.065 bore. I got the pistons but these pistons did not come with a spec sheet that my machine shop needs to do the correct work. I called summit but they really dont have that info. The main specs we need is the piston turn diameter and at what degree. Also does anyone know who makes summits pistons?
Old May 21, 2021 | 01:32 PM
WE TODD DID's Avatar
If you have a 4.065" bore piston, the cylinder needs to be 4.065" diameter. The clearance is already built into the piston. Although I do understand wanting to make sure what you have is correct, an experience machinist knows where to measure the piston.
Old May 21, 2021 | 10:56 PM
indyjps's Avatar
Agree, blocks Ive had bored, machinist wanted to measure the piston vs trusting the piston was manufactured to spec on a sheet of paper.
Old May 22, 2021 | 01:17 PM
Corona's Avatar
There's a Summit Rep who posts Here. Find him and he maybe able to Help.
Old May 24, 2021 | 12:52 PM
Summitracing's Avatar
LS1Tech Sponsor
OP,
We apologize for any confusion or frustration. There should have been an instruction sheet like this one in the box with the pistons.
To clear up where to measure the piston. All of our PRO LS pistons have a gauge point in the skirt coating 90 deg. from the wristpin. Also, they are machined with .004" clearance built-in. As others said you would machine the block at 4.065" for these particular pistons.
The below image shows where the gauge point is located.
__________________
800-230-3030
www.SummitRacing.com
Old May 24, 2021 | 03:07 PM
Corona's Avatar
Told Ya!
Old May 24, 2021 | 05:11 PM
The I ssue at hand is that the shop didn’t know this. Any machinist worth a poot should know this. I’d find another shop.
Old May 25, 2021 | 08:20 AM
Corona's Avatar
I Believe i understood it Before I typed it.
Btw the way the picture is Scratch and Sniff.
Old May 26, 2021 | 12:40 AM
1FastBrick's Avatar
I lost my sense of smell due to Covid-19. Can you tell me what it smells like???
Old May 26, 2021 | 05:11 AM
rkupon1's Avatar
^^^burnt $100 bills^^^
