What heads for a N/A 408ci?
Old Jun 1, 2021 | 01:36 PM
Mavn's Avatar
"I MAID THEESE"
Default What heads for a N/A 408ci?
Never done a N/A A408 before..
What heads would you run?
Milled stock ls3s? How bad do ls3 heads shroud the valves on a 408?
Manual 3100 lb car with IRS
All motor setup to roll race and just be fun on the street
Heres the combo
6.0 block
4.030 bore Wiseco -3cc flat tops
4" stroke
Summit Stage 5 Cam
247/255, 113.5 + 2, 625/.615
Either a
TSP SR-3 intake
or a FAST 102
Old Jun 1, 2021 | 01:44 PM
Corona's Avatar
Ask Eric Roycroft... I'd say Shrouding isn't Even a Major Concern. It's a LS 1 tech BS conversation to Try and Sell heads.
I maybe Wrong ....but I doubt it. Ask A porter Who's not Trying to Sell u something 4 Facts!
Btw it's Fake News. How do I know? Dart Ls3 Heads @ 280cc 👈 😂🤣 on a Darn Ls2 402 which Has Nothing different than A Factory Ls3 head.
Project Escalation
Old Jun 1, 2021 | 01:57 PM
Corona's Avatar
You asked a loaded question BTW.
How does anyone Who Doesn't Port Heads know The Facts on the Question asked?
😏😉 I've asked Every Question Known to Man about anything dealing with a LS HEAD. 🤫
ER will say if it's the Exhaust it's not a Problem Some guys move the Dowels and go with a Smaller Valve.
If you wanna get a aftermarket head Just get 1 but the Shrouding thought isn't Worth the Time nor the idea of Finding X amount of HP. If you wanna Move them Move "Em, on the Dowels.
Old Jun 1, 2021 | 02:04 PM
Corona's Avatar
Also your Cheating Yourself with that cam LIFT.
Steal the Spec's and give it 650 lift 🤣😂
Cam Motion FTW
Old Jun 1, 2021 | 02:06 PM
If shrouding isn't an issue on an LS3, it SURE won't be an issue on a 408.
Old Jun 1, 2021 | 02:19 PM
Haggar's Avatar
Well... LS3 = 4.065" bore, 408 = 4.030", so shrouding is worse on the 408.
But LY6s sure seem to outperform LQ4s....
Old Jun 1, 2021 | 02:21 PM
Mavn's Avatar
"I MAID THEESE"
Cam Motion FTW
Summit is my people. I would never steal their specs and add lift . Thats ridiculous .
Old Jun 1, 2021 | 02:25 PM
84ta406's Avatar
My engine is a 402 and I went with Mamo 235 heads, should make great power and have plenty under the curve. Not saying LS3s won't just the direction I decided to go. Cam is 243/249 .675/.675 114+3 so fairly aggressive. Compression works out to 11.8:1 with DCR in the 8.3s for a pump gas friendly build. Tony estimated in the 630-650hp range, but I'm also doing a Meziere 329 and GZ Vacuum pump.
Old Jun 1, 2021 | 02:28 PM
Mavn's Avatar
"I MAID THEESE"
I love cathedrals . I already have the intakes so thats whats leaning me towards ls3s. I bet that 402 is nasty!
Old Jun 1, 2021 | 03:11 PM
Corona's Avatar
Originally Posted by mavn
summit is my people. I would never steal their specs and add lift . Thats ridiculous .
No Love Nor Loyalty when Talking HP... Just Straight Shooting. 🤔 Summit can Ponder about it Afterwards When purchased With LIFT. 👍
no Love Loss or added. If you get Special treatment on Cost that's A Whole Different Story.
Old Jun 1, 2021 | 03:15 PM
Corona's Avatar
Again G
Don't Forget SpeedTrigger
4.005 X 4.00 = 402ci + Dart Ls3 heads = 700fwhp
Does the Dart heads have the Valves Moved?
No...
Old Jun 1, 2021 | 03:22 PM
Z28SteveA4's Avatar
Trickflow 235 heads here on a 403 and also on an older customers car that had a very similar setup as mine. Awesome head but it’s cathedral port
Old Jun 1, 2021 | 03:29 PM
OOOPS I did forget the 408 has a smaller bore. MY BAD!
Old Jun 1, 2021 | 03:43 PM
low2001gmc's Avatar
MASS seller approved
Don't worry about heads. They'll be fine. I think the duration is a bit much for a fun street car. Seems more for a max effort build. The 625 lift is good especially with trunion upgraded only stock rocker arms. I would go with fast for fun street car and tsp sr3 for max effort. I guess perhaps reevaluate between fun street car and max effort... Just my 2 cents.
Old Jun 1, 2021 | 05:29 PM
Mavn's Avatar
"I MAID THEESE"
$200 cam vs a $490 Cam to gain what? Maybe 10 hp up top and less spring life. Im good .
Old Jun 1, 2021 | 08:35 PM
Corona's Avatar
👍 Good Springs will last ... But + on cost
Cheaper Cam wins. Keep it Cheap all the way Through. Hp is and will be there with More Cubes your just not Trying to Get after it. Keep it Simple and Fun... 600 hp isn't Asking Much 625 isn't Either.
Out think the 408 Cathedral head Test?
Compare your *cam* and build to the one used in the test. My thoughts are Skip asking just Find something Similar to Set the Mark. It's a Basic Private Fight your Doing. And What You may Want.
Easy Guess Estimate of what you may have Before hand. 👇 Only a cam Difference?
https://www.hotrod.com/articles/hrdp...der-head-test/
Old Jun 2, 2021 | 12:46 AM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
My .02 with that cam (+8 Exhaust Split) and FAST Intake.....
AFR LS3 with hollow intake, solid exhaust valves (100g/99g).
260 CC outflows 280 DART EVERYWHERE
Intake & EXHAUST up to .700"
Old Jun 2, 2021 | 02:04 AM
Corona's Avatar
Mast Ls3 heads Vs The Catholic Heads would Be about the Same as the Heads u Listed in terms of Performance?
Old Jun 2, 2021 | 01:10 PM
lazerlemonta's Avatar
What gears are you going to put in this thing? If your staying stock your over caming the combo to be a lazy **** lol
Old Jun 2, 2021 | 02:49 PM
Mavn's Avatar
"I MAID THEESE"
It has 3.46 out back
Heres the trans ratios
4.06 2.4 1.58 1.19 1.00 0.87
