To stroke or not?
Old Jul 13, 2021 | 06:39 PM
  #41
CCW cranks won’t “jump rope” or flex in the center at high rpm (7500+) like a non-CCW will. Bearings will tell the tale. But…the OEM LS/LT blocks aren’t machined for the CCW cranks. There was a thread here once upon a time talking about CCW cranks in an OEM block. Unless there’s a heavy filet in the CCW counterweights to clear the center Oem webbing, the CCW crank won’t work.
Old Jul 13, 2021 | 08:20 PM
  #42
Corona's Avatar
We got a Super One man band guy on YB...there's a Few but this Guy tops Many. He has Manufacturers make Stuff for him...Aka the gen3 hemi, but here's what's Said on what you Spoke on Chevelle...
I luv this Guy
https://www.yellowbullet.com/threads.../post-72661445
https://www.yellowbullet.com/threads.../post-72697651
Old Jul 13, 2021 | 08:22 PM
  #43
Corona's Avatar
Another UnKnown Teacher that's Around...
btw he knows I luv's him....
Old Jul 14, 2021 | 06:52 PM
  #44
I luv this Guy
I looked through the thread. So it’s fuzzy to me….did he grind or mill the crank? He mentioned grinding it, but then shows it in the block and doesn’t talk anymore about cutting it. Then another guy at the end of the thread says he could verify that it’s a drop in.
I’ve never seen Callie’s info on the fitment of the CCW cranks, but I’ve seen other manufactures of CCW cranks that specifically say they won’t fit an OEM block.
Old Jul 14, 2021 | 07:39 PM
  #45
Corona's Avatar
Spoiler!
What's Being Talked about from the Start and Grinding?
Context Clues?
Crank grinding was NEVER Spoken on by the One man Band.
Old Jul 14, 2021 | 07:41 PM
  #46
Corona's Avatar
From the way I read his post no clearancing is required. The center counterweights are tapered and miss the bulkhead by .060" - .065" so it is a drop-in affair.
*As noted previously my Dart crank required minimal clearancing but it has full profile center counterweights*....
Minimal Clearancing to the crank
Because
"The (blocks) that need clearancing can be done in about 30min on the mill. Not a big deal at all."
"I have done it on a 6.0L with a 4.00 Dart billet CCW crank."
Old Jul 14, 2021 | 07:48 PM
  #47
Corona's Avatar
The 1 Man Band Never Showed pictures...
You getting Confused without me Typing says Alot
👍 From the 💩 talker
Old Jul 14, 2021 | 08:38 PM
  #48
Corona's Avatar
Chevelle We"be got a Great Fight 2 night!
Either Or...Fight!
The MVP vs the Old man and His Hit 🎯 man in
Devin Booker we Trust.
Didn't feel @ home until I heard about What's been Happening in the City... Or Streets. 👍
You Should have Seen my lawn after 2 wks in Houston and 🌧️
Old Jul 15, 2021 | 10:04 PM
  #49
Corona, I’m quoting myself here…which is laaaaame…but I wanted to re-visit this for the tech, in order to help others out there see just how big the filet in the center counterweight needs to be. Check out the pictures in post #1 of this thread…link below…and slide down to pic of crank in the block. Focus in on the center counterweight and check out the filet of the Callies crank. Looks like it’s been messaged a little bit also.
https://ls1tech.com/forums/generatio...20-engine.html
Old Jul 17, 2021 | 09:50 PM
  #50
Confirmed that the Compstar CCW cranks will drop in an Oem block without clearancing.
Old Jul 18, 2021 | 08:43 AM
  #51
Corona's Avatar
In the 1 Man Band ...I Trust!
