To stroke or not?
original plan was to swap the 6.0 in place of the 5.3 in my 2001 Silverado. It’s a z71 4x4 with a 4l60e and 3.73s on 34s. I’m aware the 60e would live a short life behind either engine so I’ll address that separately.
the bores on the lq9 are actually flawless the cross hatching is still visible and this is actually one of the cleanest engines I’ve ever torn down and inspected. So I’m thinking I’ll lightly hone the cylinders since I already have a single ball.
Since it’s a truck should I go for the extra cubes? I will be towing a boat every once in awhile. It’s a daily driver but I take it on road trips, camping, tow and adventure out into the desert and woods, and snow.
Decisions...Decisions!
Center Counter Weight is for a Person with the Need of 8k +
Stroke Before anything Top End.... Cam, heads, etc.....
6.0/6.2 reference...= 402 to 418 easy....
Kills anything below it with Cubic inches without the Help from the Punk / Pump of Forced Induction....
How big of one you build or how much air it can move depends entirely on you. You can do to one without doing to the other but your just defeating the purpose.
Rpm does Equal to a faster ET but if,
no $
Reliability is Momma.
Everybody Loves Momma...
Like guys Need to Watch Yellow Stone... & Kevin Costner
Simple on Simple and good Drinking & Watching to make you Think... I need my New Season!
My Fault. Watching Yellowstone.
Keep it Simple with Common Sense..
$50 to $100 to $150 dollar Used Factory crank... all depends on Who's Selling....75 sound like me and what I'd pay.
$600 - 750 dollar 4.0 crank ....I paid $700 no Tax
As cast non Forged cost even Less...
Both Use 6.125 rods.... H beams $550 I paid...
Piston are a Wash .....they sell Either at Bottom rate cost ....
Either would Like to be Balanced... $150+
When back In Houston ....$150+ goes to 👆 Covering ....duh Balancing....
But if you've got a tight Budget .... common sense...
Hell just buy a Used 6.0...the one I sold is Still being used...
Elijah got that from me for $400 the Entire engine. I took his Rod Bearing Knocking engine And Scrapped everything....Spare Block.
The following 2020 Hot Rod Magazine article was a little strange, but interesting at the same time. It started off as a test of "stage 3" cams on a stock LS3. After a baseline, they plugged in our Pro LS SUM-8710 230/242 113 + 3 .625/.605 cam. Next up they wanted to try SUM-8705 (identical to Chevrolet Performance Stage 3 234/277 .595/.595 lift 107 LSA cam). Look at the exhaust duration and LSA and it's little wonder that the flycutting required to run that would have made the LS3 piston a time-bomb. So instead, we did what anyone with an unlimited parts budget would do and threw a Pro LS forged stroker rotating assembly at the problem. Easy peasy. Problem solved. We jest, but it's all in the name of science. This back to back test gave us some very good data on what one could expect to happen with common 4" stroker cranks and the power curve.
Here's the Hot Rod article
thinking I’ll run the above crank, and these pistons
https://www.summitracing.com/parts/dms-k1931-4000
that’ll allow me to use my current gen 4 rods
Summit Racing, do You Guy's offer the or a
Center Counter Weight Crank? If so is it at Fair market place cost? Maybe a good idea if not into production...
