LSX Stroker and Supercharging?
Car is a weekend street car btw...
Are the summit cranks counter weighted?
This might be a better question for the FI section?
Also, no one has talked about the impact of the bigger stroke on max boost.
you will be feeding more cubes. Like for like, max boost will drop.
Donyou want to spin the blower faster?
Any forged crank and rods should handle everything the 2300 can put out.
You’re going to make the same peak power roughly with a 3.622 or 4” crank. Boost level will be higher on the smaller motor but who cares. Running a lower boost number to make the same power is over rated at the levels the 2300 can make. It really boils down to do you want to make peak power at a lower rpm and need more torque down low? If not the 3.622 will be the better choice.
My setup so far is : GMPP 821 ported heads with upgraded Manley valves, TSP dual springs, Ti retainers, CHE Trunnion upgrade, TSP Stage 3 blower cam, Morel Lifters, TSP Pushrods, LSX 376 iron block, (forged pistons, rods, crank - soon - 9:1 / 9.5:1 CR), TVS2300 with 2.6 pulley (rear cog drive, IW 8 Rib setup with 10% Crank OD as well, ECS Tensioner). Factory fuel pump on BAP and secondary is ECS setup with Aeromotive pump, 1000cc Injectors... Trans is T56 with Mcleod RXT kit. Water-Meth kit also. I think I might be forgetting something lol. Think I could break 1000 even if briefly on the dyno?
I might just get the stock forged setup from Summit and call it a day...
The TVS2300 isn't a "big" blower and is somewhat limited for big power. +/- 800 rwhp is about the practical limit. Sure, bigger numbers have been made, but at a hell of a price
A bigger engine will run at less boost compared to a smaller one. I'd keep the static c/r at 10.5 if you're looking max power. Maybe a little less if you don't have 93 octane available. Meth will help with the octane level, but won't do much for cooling the intake charge as the meth is injected pre blower. On my Heartbeat blown LS3, I went from 640's at the wheels to 660's with the addition of meth. That was at 9.5psi with mild blower cam and all the bolt ons. Hardly worth it vs straight 93. If you're limited to 91 octane, it might be a better idea.
My setup so far is : GMPP 821 ported heads with upgraded Manley valves, TSP dual springs, Ti retainers, CHE Trunnion upgrade, TSP Stage 3 blower cam, Morel Lifters, TSP Pushrods, LSX 376 iron block, (forged pistons, rods, crank - soon - 9:1 / 9.5:1 CR), TVS2300 with 2.6 pulley (rear cog drive, IW 8 Rib setup as well, ECS Tensioner). Factory fuel pump on BAP and secondary is ECS setup with Aeromotive pump, 1000cc Injectors... Trans is T56 with Mcleod RXT kit. Water-Meth kit also. I think I might be forgetting something lol. Think I could break 1000 even if briefly on the dyno?
Yeah its not looking very promising for 1k with the TVS2300 unfortunately
I've been told the only other way to momentarily break 1000 on a dyno is with a quick shot of NOS lol. Idk if I want to do that though...@old motorhead, I am gonna have it tuned for 93 octane as I have it almost everywhere over here and we where gonna put race gas in it as well (when trying to reach the hp goal on the dyno only). Oh and yeah I've been thinking about going 10:1 CR.... Oh btw its the jackshaft version of the TVS2300, one of the recent ones as its still fairly new.
@BCNUL8R yeah I think I'm gonna just go with the stock stroke and yes 93 Octane tune - I would like to go to E85 later and better fueling but idk.... decisions, time and $$
Guess we will see what happens
Thanks guys!
Is this an actual LSX block? You say LSX376 so if it is an LSX block you can go way bigger on bore which is what I prefer. More bore and short stroke then put the bigger blower on it if you can sell the one you currently have. Torque will not be a problem with either blower and you can't go wrong with either stroke length. I just like the biggest bore I can get in my budget and a shorter stroke. No science behind it just something I like.
I never sai d it didnt make power, of course it does. I think it's perfect for a weekend toy or grudge car. To run it in a daily sucks, though, at least where I live(SoFlo). The amount of driving necessary here s substantial and the 4mpg will wear you out. Have had friends/customers all try it, love the power, hate the drivability. It's all personal preference, I was just sharing my opinion on it.
Maybe one day that will be my blower of choice haha
