Rollmaster CS1190 timing set installation question
Old Feb 16, 2022 | 07:50 AM
  #41
99 Black Bird T/A's Avatar
Jorgzee1, that picture of the gear drive rock.
⚙️ ⚙️ Gear drive for the win!
Back home in the 90's, a guy ran around in a 3rd Gen Camaro w/ 305 V8, telling everyone he had a supercharger. They heard the gear ⚙️ whine and they believed. Long time no one would mess with him at a stoplight etc.He wouldn't EVER go to the track. 16 second car had a noisy gear drive timing set & nothing else.
He finally admitted to this BS as an adult years later.
Old Feb 16, 2022 | 08:17 AM
  #42
Darth_V8r's Avatar
Moderator
Originally Posted by Mickyinks
I went to the double roller after stretching a c5r chain. Singles have been breaking if they havnt used a quality harmonic balancer.
i think rollmaster have 5 different length chains for ls so you can get them so theres minimal slack.. I have the cam plate with grooves so no need to camfor, dont know how i got it tho
This is one thing I see neglected that seems to impact a lot. I've chased many problems back to balancer issues.
Old Feb 16, 2022 | 01:40 PM
  #43
grinder11's Avatar
Now THAT'S a JIM DANDY!!! BTW, I agree with DarthV8r on harmonics. BIG problem if not minimized. I once saw an LS7 head cracked in half!! It was on a road race C6. Had a shaft rocker setup, and the builder thought it had to be something in the harmonics. A roadrace engine is a whole different thing as far as building a reliable engine is concerned. A lot of us are foot-to-the-floor for 10, 11, 12 seconds. Roadrace motors are sometimes hour after hour, IF they can last that long. I always thought that a story I read about the original SBC said it all. It was talking about how dominant the engine was in all areas of competition. Then the next sentence said " Only Indy's brickyard has eluded the little Chevy." So endurance will always be a problem for consumer designed engines.....
Old Feb 16, 2022 | 11:17 PM
  #44
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Originally Posted by Launch
On my original heads/cam ls1 car i owned many years ago it did 70k miles of street/strip beatings and went threw several different cam swaps. I used the same Rollmaster double red series chain from the beginning. The final day i pulled it down to swap out the cam/heads and return the car to standard to sell it, the rollmaster chain was still tight. I was impressed and sold on them ever since. Not saying other chains don't work but i don't see the double roller is a detriment. Now for people like Mick above running heavy springs because large solid roller... the extra force required to turn the cam against the heavy springs is being transferred from the crank through the chain. The chain takes even more of a beating. So why would you risk a single chain when the double has been proven reliable for decades in not just LS's but everything else as well.
Worst part for me was having to clearance the timing cover on my current LS2 for the double chain, was probably more of a pita than the entire engine build. I never had to clearance it on my ls1's for the double chain. I didn't bother looking into why that is or what the difference is, i just got the die grinder out until it fit.
Its not a risk on a single chain. Literally no one can quantify that. There are too many running singles at well over 7k rpm and with any spring you can imagine and any amount of boost or lobe design for it to be anything other that real world proof. On endurance and drag and daily.
The literal unicorn of the LS timing chain mythos the IRL chain is a single roller. Had a double roller been better at any point, they would have used it, and gm would have adopted it into every mill from then on, just like they did previously in other generations of engines OR offered it as a "performance part" option so they could use it in racing bodies with tight rules. Its not. So they didnt. Its literally that easy to look at.
Many of you may not know the history behind the chain because it was gone for a while then reintroduced then gone again, but quite a few know about the IRL and the abuse their engines go through and how turned up they are.
Its not "cheap insurance" when the single rollers hasnt been proven a weak link at all. Even the stock ls1 or ls2 chain. More work for the same outcome seems counterintuitive.
As for the gear drives.....GoTTA Ask bArb about dem whiney gears when i crank my hog GOBBLES
Old Feb 16, 2022 | 11:36 PM
  #45
theunderlord's Avatar
amen dude.
Old Feb 18, 2022 | 09:03 AM
  #46
jorgezee1's Avatar
For future reference could someone provide the
SAGear single LS roller part number?
LS3 (4x) stock 1 bolt version set seems to be part number
78935T-9
LS3 (4x) 3 bolt version single roller.
08-9036t-9
Old Feb 19, 2022 | 03:17 PM
  #47
1FastBrick's Avatar
Originally Posted by RedXray
Hey Brick could the counter sink be used in a drill press?
link?
Wasn't able to get to it last weekend but here it is. The used one I have just barely fits a 1/2 chuck. It fits 9/16 collet for my mill. I dont have a speed adjustment for my mill but it does the job. Takes longer to set up and center it then it does to make the 2mm chamfer...
Old Feb 19, 2022 | 08:29 PM
  #48
I like this. Great post!
Old Feb 20, 2022 | 12:36 AM
  #49
1FastBrick's Avatar
Thank you! Happy to share.
Maybe it will help others.
Old Apr 2, 2022 | 08:20 AM
  #50
SnIpEz's Avatar
78935T-9
08-9036t-9
Old Apr 3, 2022 | 07:06 PM
  #51
RB04Av's Avatar
Those applications look a whole lot more like sprocket sets with NO pulses per rev. Motors in those years used a cam sensor in the back of the block that looked at a feature on the cam. There was no "pulse" feature on the cam sprocket whatsoever.
Neither of those applications (which all consist of the same part #s) will work in a LS3, which needs the 4x cam sprocket.
Old Apr 4, 2022 | 09:39 AM
  #52
jorgezee1's Avatar
Agreed, the image posted by SnIpEz is not for LS3 engines. He might have just wanted to add more part numbers to the thread, as he highlighted 5.7 applications.
The LS3 4X sensor part numbers are what I listed earlier. To be clear, these are "SA GEAR" part numbers not Roller Master part numbers.
78935T-9
08-9036t-9
Old Apr 4, 2022 | 10:27 AM
  #53
BCNUL8R's Avatar
I’ve had the roll master single in my ls3 block for 2 years now without issues. I did have the paper about modifying my cam retainer in my kit so I did so.
I run a stock crank, Procharged at 20 psi, shifting at 7200 rpm. Cam has .621 lift on the intake, pushrods are summit 11/32 .120 wall and rockers are ws6store max effort.
