LMG build progress!
Old Mar 20, 2022 | 08:59 AM
Utinator's Avatar
Default LMG build progress!
I just started assembly of my first engine. I used Durabon cam bearings, and King mains. I got one of the last BTR v1 truck cams. I thought it was going to be a 3 bolt cam, but it turned out to be one bolt. So, I reused the stock cam gear and bolt.
The cylinders needed a light hone due to rust. It sat for a while before I bought it. There are still some scratches that wouldn't come out. Do my cylinders look ok to use?
Old Mar 20, 2022 | 09:07 AM
Utinator's Avatar
More pics.
Old Mar 20, 2022 | 09:10 AM
Utinator's Avatar
Old Mar 21, 2022 | 05:15 AM
jasons69chevelle's Avatar
Make sure everything has been cleaned. Cylinder walls, all mating surfaces, all oil passages and is rust free before assembly. A dial bore gauge, micrometer, calipers will give you a exact clearance so you know what oil to run. Don’t forget to set/check the thrust bearing clearance.
The vertical scratches just look like they are from the old rings. They should be okay as long as you can’t catch a finger nail in them. Can’t see the angle of the cross hatch very well.
Old Mar 21, 2022 | 05:15 PM
Utinator's Avatar
The cylinder walls are smooth. It was super bright outside, so I couldn't get any good pics of the cross hatch. I'll try to get better pics next time.
Old Sep 26, 2022 | 08:32 PM
Utinator's Avatar
UPDATE:
The audio is kinda weak. It made 425hp/408tq
Old Sep 26, 2022 | 08:37 PM
68Formula's Avatar
Interesting build... short block straight to dyno! Congrats on the horsepower.
Old Sep 26, 2022 | 09:03 PM
Utinator's Avatar
Yeah, I kinda lost track of this post. I didn't really make an official "Build Thread". So, yeah. Now it's for sale. It is listed in the classified section here.
It's just a BTR stage-2 truck cam in a mostly stock 5.3L. I ported the heads, which is covered in another thread here. Nothing special, really. It's my first build, but I want to do more. Gotta sale this one first.
