NA C6z Build
Old 08-10-2023, 08:13 PM
  #281
Bob570's Avatar
I can't wait to see how this thing does
The following users liked this post:
jayyyw (08-11-2023)
Old 08-10-2023, 08:14 PM
  #282
01CamaroSSTx's Avatar
Received 1,883 Likes on 1,360 Posts
Well it's full of goodies and ought to make some sweet music.
The following 2 users liked this post by 01CamaroSSTx:
DualQuadDave (08-11-2023), jayyyw (08-11-2023)
Old 08-16-2023, 06:43 PM
  #283
jayyyw's Avatar
It’s alive, again! Haha.
View this post on Instagram
Needs an alignment and a tune, bad.
The following 9 users liked this post by jayyyw:
01CamaroSSTx (08-16-2023), 02EBC5Z06 (08-16-2023), ALL ULL C (09-18-2023), Bob570 (08-16-2023), brutalzo6 (08-16-2023), C5_Pete (08-18-2023), DualQuadDave (08-16-2023), rkupon1 (08-17-2023), SlowTBSS (08-16-2023) and 4 others liked this post. (Show less...)
Old 08-17-2023, 12:45 PM
  #284
Double06's Avatar
Default Vacuum pump
Are you running the gz 102 or 104 vacuum pump how do you like it? Or too early to tell.
Old 08-17-2023, 12:52 PM
  #285
02EBC5Z06's Avatar
Its the 104.
Old 08-17-2023, 07:08 PM
  #286
rkupon1's Avatar
Who s doing your tuning and what software?
Old 08-17-2023, 08:18 PM
  #287
jayyyw's Avatar
The larger one, so I guess the 104. I spoke to GZ and this is what they recommended for the RPM I wanted to turn. It works great. Need a larger catch can than they offer with their kits, IMO. Tried it on the last car and it just spit oil out of the filter everytime I drove it.
Old 08-17-2023, 08:19 PM
  #288
jayyyw's Avatar
I'm trying to mess with it myself, but if I can't, my engine builder will be doing the tuning. Its on a Holley Terminator X Max
The following 3 users liked this post by jayyyw:
02EBC5Z06 (08-17-2023), DualQuadDave (08-17-2023), rkupon1 (08-17-2023)
Old 08-17-2023, 08:22 PM
  #289
Bob570's Avatar
I can't wait to see the videos of you ripping gears and handing out gaps with this setup. I'm also curious to see how you and Gap God stack up.
jayyyw (08-17-2023)
Old 08-17-2023, 11:03 PM
  #290
jayyyw's Avatar
He got me pretty good last time we lined up but there was about 100whp difference between both cars. Hoping the power difference is much closer this time around. He actually helped me drop the motor in the car.
DualQuadDave (08-21-2023)
Old 08-21-2023, 11:52 AM
  #291
Ryans99ls1's Avatar
Not sure if you posted it here, but what you are thinking this thing will weigh in at with you in it? 2800lbs? You've got a lot taken out.. that power to weight is going to be killer
Old 08-23-2023, 07:13 PM
  #292
jayyyw's Avatar
It should be right around 2900lbs with me in it. I'm not light @ 280lbs.
Ryans99ls1 (08-24-2023)
Old 08-23-2023, 07:14 PM
  #293
02EBC5Z06's Avatar
Ughh same 😔
jayyyw (08-24-2023)
Old 08-24-2023, 12:28 AM
  #294
jayyyw's Avatar
Originally Posted by 02EBC5Z06
Ughh same 😔
Big boys unite!
Old 08-30-2023, 07:20 PM
  #295
jayyyw's Avatar
Looks like it will be closer to this, with me in it.
Old 08-31-2023, 10:06 AM
  #296
Ryans99ls1's Avatar
Badass. Car is going to punch well above its weight class at that weight. Well done.
jayyyw (08-31-2023)
Old 08-31-2023, 09:00 PM
  #297
jayyyw's Avatar
Did some preliminary testing the other day. It looks promising. Been awhile since i've been behind the wheel in something "fast". Got scared during a 3rd gear pull and let out around 8000rpm. Fuel flow was still slowly climbing.
The following 2 users liked this post by jayyyw:
02EBC5Z06 (08-31-2023), DualQuadDave (09-02-2023)
Old 08-31-2023, 10:07 PM
  #298
Received 3,528 Likes on 2,173 Posts
8k in 3rd is what…130ish?
Old 09-01-2023, 12:40 AM
  #299
jayyyw's Avatar
More like 123ish with my gearing. My tachometer doesn't read passed 7500, so it was more like afraid to keep pulling it in 3rd. Shifted to 4th at 8000 and held it for a second. Acceleration felt very strong for the conditions. Had timing pulled out of the whole map due to the subpar pump E85 in the tank.
DualQuadDave (09-02-2023), hiltsy855 (09-05-2023)
Old 09-08-2023, 02:03 PM
  #300
jayyyw's Avatar
Finally got it on the dyno yesterday. I was working the keyboard on this one.
Ended up putting down 757whp and 588wtq! Just a bit off the ultimate goal we had for the build, but solid numbers nonetheless. There was a few things I wanted to try that would have made a little more power but wasn’t able to. Time to dial it all in on the street.
Also got my alignment sorted out too.
The following 11 users liked this post by jayyyw:
02EBC5Z06 (09-08-2023), ALL ULL C (09-18-2023), Bob570 (09-08-2023), brutalzo6 (09-08-2023), C5_Pete (09-17-2023), Double06 (09-08-2023), DualQuadDave (09-09-2023), gnx7 (06-08-2024), logan2ss (09-08-2023), Mickyinks (09-09-2023), wretched73 (09-08-2023) and 6 others liked this post. (Show less...)
Quick Reply: NA C6z Build
