NA 417 build give me ideas
#41
With your weight you should be able to run 9s with your old set-up. I don't see it being a problem with your new engine with the power you should make. You might want to look at a pt4000 converter though. It won't hit the tires as hard on the launch and will have better shift extension to keep you in the rpms you want on the shifts. I've tried both ss and pt series and the PT worked better for my n/a setup.
#42
The following users liked this post:
65LSXNOVA (05-19-2024)
