how many miles is too much
I know LS engines are great, and have read a fair amount on these. And yes, if you as ask a million questions, you might get a million opinions ..BUT here goes
I built an L92 for a 69 Camaro, pro touring with 120K, junkyard swap..cam change, valve springs, terminator X, no problems, runs great
I am now building a dedicated track car, road race..Lime Rock, Thompson, etc..a swapped Porsche Boxster S with a L92...going mild, cam swap, valve springs, new oil pump, chain, terminator X BUT this engine i am told has 275K on it
I checked some bearings, they look fine. I camera scoped the bores and it looks pretty good, no oil wash . BUT the question how many miles is TOO MUCH?? I am building on a kinda of a budget, and want to get it up and running, and can drop it and rebuild it later. What is the opinion on how much before it should just be rebuilt and not junk yard swapped..I just have to ask you guys out there!!!
The reliable methods would be compression test, leakdown, and bore taper. If you still have full compression and your bore taper is a thousandth or less, you can probably keep on trucking.
On the other side of that argument, if you have the engine fully torn down you may as well get a machined bottom end, especially if you intend to make much more than the stock power output.
If a customer told me they had 275K on a C-15 Cat or ISX Cummins..I would say engine is fine..A small block with that miles if it made it that far, I would say had at least a timing chain, and be burning oil like a waste oil furnace ..but a LS..Everyone says the same..check a few basics and drive it like you stole it.. What an engine! I will say that my 2015 Yukon 6.2 LT broke a valve spring at 55K Thanks for the info
But let's not talk so much about my 4L60E. It needed a $2100 rebuild a month after dropping it all in.
Rick
but like what was already stated. Mileage is subjective. My truck doesn't even have a receiver hitch. The most work I ever ask of it is taking about 4 pieces of sheetrock home from homedepot.
