Home built 416
Went with ARP main studs this time around. Yes machine shop align honed the block with the new studs.
Got the block back from machine shop and it was decked, honed to 4.070 and mains align honed.
K1 crank with king main bearings. Main bearing clearances are between. 0020-.0021. Little loose but i think id rather have lower oil pressure than having a chance of oil break down and grabbing a bearing and spinning.
Wiseco -8cc pistons where selected to help keep compression under control with the 61cc heads.
Piston specs
Rod bearings are coming out to .0020-.0021. Im thinking about swaping to a different bearing. These are king xp. I think I need .0025 rod bearing clearance. Its a street strip car that has a loose converter and will live between 6000-7000 rpms at WOT for 9-10 sec at a time. (hard on bearings)
But for 99.9% of LS builds, simply opening up the oil grooves with a fine round file after setting up the thrust clearance is plenty, as long as it has enough oil pump and viscosity is correct.
Crank tapped forward with dead blow hammer and zeroed out on dial indicator.
Pushed back with small screw driver looks like .007. I think thats pretty good.
also have some x bearings coming for the rods to try and get that clearance opened up closer to .0025
