Engine rebuild gone wrong!
Try a different weight oil and new filter see how it responds.
There is plenty of things that can be done before a complete tear down.
The reason I mentioned the Pan oil pressure relief is because in some cases they were bleeding off pressure and causing a low pressure issue for some higher mileage engines. As soon as they installed a block off the Pressure went up to around 50-60 PSI.
Try the thicker oil first, and see how it responds. If it still similar issue, then you can drop the pan and do some more inspections and make changes.
On the upper plate the o rings are important so if you didn't install them or it fell off that could be an issue.
- Valley Cover: - ICT Billet DOD delete valley Valley Cover with oil sensor adapter (ICT #551605 & 551623). Includes seal and bolts.
yes i installed the o rings. Could one have fallin off ?? I doubt it i checked them real good.
Trying a thicker oil is only an indicator and not the fix.
Rod bearings or cam bearings? Well not good!
So we can rule out o rings, oil pressure relief valve and oil pressure switch. I was thinking i would replace the oil pressure switch and plug the oil pan pressure release valve. If i have the pan off should i recheck the bearing clearances? If they are in spec then its cam bearings?
Is it to much clearance or to little clearance?
What a mess!
How does it get its signal different from cluster gauge?
i wish i would have installed a new oil pressure sensor when it was easy to get too. But thats easy fix if thats all this is.
