PRC 285cc LS7, Real Head flow data?
I seen what i think was a 265cc test where they barely flowed more than a stock LS7, and looks like they changed the guides up since that was done...
Yes I don't want to invest 5500 in a set of Mast or other heads when I could buy a used procharger for the price difference....the Trick Flows come with a lifetime warranty but I'm having trouble finding someone I could send them to that would do the light short side and bowl/throat bleeding work they need, iron mask won't even answer my emails or phone calls, Katech does but they only deal with stock castings which would cost the same at these PRCs when done???
I did search but I can't find it, any deals out there better than this, also they will be going in at 12 to 1, in front of an auto with 4400 stall...thought about maybe going to a street style solid roller down the line and I have ST2126SLR lifters fir it as well.....
Thanks
I didn't know they had subpar aluminum, thats huge to know..i noticed the Frankenstein of similar price( 3600 ti) i think M711s say basically off shore casting machined by them, so they denote it may be lesser aluminum/casting at least. But yea to me right now 2000 is a lot more but I absolutely 💯 appreciate the feedback....did you dyno or race the 265s ( i guess those would be comparable to a trick flow out the box, according to the only REAL flow thread I can find? Did you have your 265s flowed? )...
I may wait, I won't deal with MAST again they really hosed me over but maybe a BR7 variant done by a reputable company if I don't roll the dice.....like an LME, Hoopers, wcch ect
Thanks again......
Thanks again......
You have a nice parts list here, and I like where your going. Please don’t skimp out on heads. You will regret it. It’s cheaper to pay the $4k+ now than to “only” pay $3k now, and then have to pay $4500 later because you “saved a couple thousand” to start with. It’s an expensive hobby. Do it once and do it right. It’s waaay cheaper in the long run.
I seen threads where they point to preload come on man, preload I could see wanting up from specific swipe/scroll patterns with proper geometry and should specify preload for popular lifters but preload that's not insane aka bottoming out or loose bouncing, or spring vs ramp rates aka have an approved cam and or lobe profile if your not gonna stand behind it....
One thing about Trick Flows thru summit is they have a lifetime warranty period.....
I did send an email to Tony ive used his BBC heads before, to see if he would do his port work ect without forcing me to run shafts right now ( not that it's not on the menu after a successful break in and recovery later ) and I don't want to run the ported msd nothing against it but the hi ram fits in my car with its current cowl hood and I know it's not popular here but an old 67 Camaro needs to be slightly raw but I still want my rpm
vs the refined balanced mamo trick flow/msd system hehe I'm an old man yall probably don't understand it and sneer a bit but I've had that muscle car over 35 years its been in family more than that, with the sequential injection , per cylinder timing and fueling ill get a little big port low velocity driving issues out when it's a loose stall ( I can lock up at WOT ) and 4l80e, my demands are a lot less on refinement but I couldn't leave this world with my bbc and F1A-94 on it in there for my daughter and grandson to wipe themselves out in...hence ls7 big hp lower torque straighter running car
Really appreciate you all merry Christmas and I indeed look like santa....
But my god Brodix seems almost universally praised as the best base to start with and then a good port program on it....
iron mask hasn't been answering my emails or phone calls I was scared they went out of business....cause I WAS looking at them to port my hi ram to their trick flow program or indeed the BR7 program.....
I can't find anyone to " clean up the trick flows" aka little short side and bowl work...? That's a lot cheaper
That said they were only SLIGHTLY behind the Brodix 273s and Mast heads on that test, so its a damn shame they wont stand behijd their heads or offer CLEAR guidelines to a combination to buy ( even if from them aka their supplied springs with a list of their cams and when to force you to roller tips with which they WILL stand behind it, they could even offer the pushrods the only variable would be your deck height which is what going to be the same to max of .020; but they won't do that as it WOULD make the liable when the heads fail anyway )...
I'm a bit stirred up this morning, im seeing failure after failure....and it looks like im fixing to spend more money than a procharger as i scrape it together and still have no piece of mind....lol....don't mind me Santa is worn out...
I wish I could just buy the Summit offered Complete trick flows with lifetime warranty ( i guess they had to offer that to sell them when their heads started cracking in half I don't know ) and take .020 off em and hope they honor the warranty without measuring the deck plus no one but Mamo seems to want to bump that SSR and open the throat a bit to hand blend into the chamber aka biggest gains over as delivered its 2800 as it bump compression with 020 off, OR 5500 ( plus forced shafts ) for a complete do up of them which then doesn't touch BR7 ( and everyone's variants which are plentiful), Frankenstein either casting, or CID of the same price range....
in short in my obsession over Christmas I've come up with there are 100 options but really just 3 when boiled down...stock ( fails at 6k-16k used like we use em ), cheap aftermarket your prc and trick flows ( which fail same mileage ranges like we use em ), and the ole 5500 BR7, FS, and CID which don't seem to have as many issues and when they do more easily fixed ( although Frankenstein very publicly said they won't fix their heads anymore so I assume the skilled labor that was doing that for them cost to much and that probably old man was let go or he retired)....so really just one and they don't add a value over a LS3 head vs Procharger lol...
aka no good choices really
So much good information here, and many have reached out to help someone please just touch the cheap summit trick flows ( if they are selling for 2800 assembled they must cost a good bit less in reality ) up a bit and take .020 off em so when they fail I don't have to be as upset as when a 5500 head combo also fails lol...cause they ALL seem to fail
negativity aside, THIS place has the experience to help me be further out that number line before I have issues if I listen, I'm aware, respect and appreciate that...for example I thought it was a forgone conclusion anything other than a stock rocker cost power and rpm range ( while requiring more spring) from LS3 world, but LS7 world the roller tip TSP with proper swipe seem to add power and certainly less side loading so net positive on LS7....I have already learned something
hope everyone had a good Christmas 🎄!!!!
My engine is out of the car right now because of Ti rod failure, I'm planning on getting some heads from Ironmask but I'm not sure I'll be able to get them before next season starts here in Michigan. So for the time being, I'm getting new guides put in the PRC 285s and I have a set of TSP roller tip rockers to run with them, that hopefully will help with guide wear.
