403” N/A build…
who did you guys have tuning it?
That is a nice pr checker. For them to have a patent on it, I see summit has their house brand listed just like it.
MS Racing Components designed that checker. I’m ASSuming that they sell to Summit under an agreement and Summit re-brands it? I bought mine from MS and had them custom build mine to the lengths I needed.
BTR Stage 3
ARH 1⅞"]https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1550/20240226_195543_ee3d1d1f9c86534d031b17fa10de4bcf5b 7b1a8b.jpg[/img]
2011 C6 GS Manual BTR Stage 3 ARH 1⅞" 3" ORX Factory NPP
He told me the next time he blows it up, he’s going to go sleeved block 440…he ain’t Skeered.
Its a custom grind I spec'ed and had Comp build for us....I have been using some of their newer lobe designs the last couple of years with good success and this cam is another example of that
It has a good bit of lift with the 1.8 rockers I supplied (.675 / .672) which helps tap into and take advantage of the cylinder heads higher flow portion of the curve.
Outstanding results from precision and attention to details,
Tony's parts and recipe obviously contributed as well.
If I ever have the opportunity to have an engine built again you would be at the top of the list.
I was planning to use LS3 injectors on my 418 build, but I didn't think they would flow enough. I now have 80lb injectors, which I know is overkill. It's better than not having enough fuel though.
