Rod orientation.
Some say it makes no difference on a stock crank, only aftermarket.
I look at the chamfers on the rods and one side is machined, and the other is not. Some say the machined chamfer should go towards the crank counterweight, away from the other rod on that throw.
That would make only half the dimples towards the rear, the other half forward.
So, "un-confuse" me.
I want to install the pistons this week.
Thanks.
Anyway, 4th gen rods are omnidirectional. The BUMP on the 4th gen rods (it's not a dimple) points to the back of the engine from the factory, although I've heard many tales of people opening engines to find them pointing to the front, or one side pointing back, and to other to the front.
I assemble them pointing to the rear.
I think IGN-1A was referring to the groove between the crank counterweights and rods and just missed the other "o", which is the reason, it's said, that it doesn't matter which way they go.
I was debating swapping 4 of them to point the bump forward, but not sore if it's a good idea, or whether it even matters.
Aftermarket LS cranks have a radius, and aftermarket LS rods have a chamfer on one side, so the aftermarket stuff matters.
Thanks.
If that's correct then the "bump" on the rod would be to the front.
I really want this right the first time.
Right now I have half of the rod bumps forward, because the machined chamfer side of the rods is against the crank, the un-machined chamfer is to the opposing rod.
This makes the most sense to me because there is more rod movement between the crank and rod than between the opposing rods, and the slight chamfer should allow more oil into the space between the rods and crank for lubrication.
Please verify.
Thank you.
If you want to be just like it came from factory, all dimples/ dots faced rear rearward.
They only do this to speed up production on the assembly line. They only need to produce 1 piston, 1 rod, and have 1 orientation to assemble...
Otherwise as stated above, it does not matter because the OEM crank does not have a radius in the journal. Technically it has an undercut but that's a different discussion.
If Scotts done it, You can take it to the bank that it works!
I need to know this because I like to install the pistons backwards.
Lance
