Mild LS3 cam for performance
I am helping a friend put together a LS3 from a 2010 Camaro SS for mild performance over stock.
So, I am looking at something like this one (summary for AI):
BTR Stage 2 N/A Cam: This is a popular choice for good daily drivability and strong power gains. It has been noted to produce 470 rear-wheel horsepower (which translates to over 500 hp at the crank and well over a 50 hp gain from stock) when paired with supporting modifications like long-tube headers and a good tune.
What do y'all think?
Thank you.
Your 60’ time or your MPH at the end. How hobby a car is it? 4 link in the rear or stock leafs?
Our SUM-8715R1 "Ghost Cam" that a couple of other members mentioned would be a great fit for this combo. Specs on it are .600/.575, 222/234, 115+3 with -2* of overlap. We have had plenty of folks use it in 6.2's that want a nice bump in performance but they also want to maintain good driveability. This can have a near stock idle to noticeable lope depending on tuning. Pair it with our .600 or .630" lift beehives and it'll be happy out to 6,800+. It will work with a stock torque converter but a 2,500+ converter is recommended.
Here is an example of its great driveability in a mostly stock LS3-powered Corvette.
I used the sum8715 cam in my 5.3 that I took to 7400 a couple of seasons drag and autocross.
Blew engine due to oiling
And I am currently reusing the same 8715 cam in my 2016 3/4 ton as my one and only daily driver. It's barely noticeable chop, but still slightly there. Almost drives completely stock it seems
Car went 13.16@106.5 all stock.
Car went 11.84@114 with a converter, headers, drag radial, little weight reduction, air intake, rod mod intake, and 3.91 gears.
Car went 10.90@125.5 with the cam, heads, went from 1 3/4 to 1 7/8 headers. I picked up 10 mph basically from heads and cam.
Idle vid:
