LS2 timing chain set
I put one on 3 months ago and it fits on stock gears. Much more robust than LS6 see below:
The only difference between these two engines when it comes to the timing components is the cam gear. The LS2 cam gear is specifically made for the cam position sensor, without this gear the sensor can not locate the cam!
Therefore it would be highly unlikely that any production built LS6 ever came with the new HD LS2 timing chain, but if you need to replace the chain on your LS1 or LS6 it will be replaced with the new HD LS2, part number 12586482.
Thanks,
SDB
