LS2 Block with 414ci?
Started putting the peices together for my stroker. Just bought a LS2 block from Kris @ Scoogin Diggy and it's on the way.
I am going with a 4.125 stroke kit so it should have 414ci?
Doing research on a cam and etc. However, with 414ci, should I change the Injectors and fuel pump?
In regards to the Oil Pump, Whats a good brand of ported, High Flow Pumps?
Anyone had any problems with a LS1 Canton Oil Pan?
I'll have a complete LS1 with 21,000 miles and Auto tranny for sale next month (currently working in Italy). Then later the LS1 I pull from my TA. I am thinking of posting them on Ebay.
Thanks for any information,
David
Nate
Nate
Don't know if it would even be worth over boring for such little but, even if you didn't, an Aluminum 402 would still be better that an iron 408
As for the Injectors and pump, What psi Injectors and what pump?
What percentage of increase does the ported pump have over the stock oil pump?
Thanks for the advice !
I don't have an LS2 block, but I went with the Eagle crank, Eagle H-beam rods with ARP L19 bolts, and Ross pistons. I spent under $2k on parts.
Get the upgraded L19 rod bolts if they're an option for you. Worth the extra $80-$100.
If I were to do it over again, I'd probably go with 42# injectors, and go with the Racetronix in-tank pump setup (if it's offered for your car). I currently have 30# SVO injectors with the Racetronix setup, but have not had a wideband on the car yet.
As for ported pump, it's not really a 'percentage', what they do is to smooth the entry and exits of the pump, and then put a shim under the spring to allow more pressure before the bypass piston kicks open. Not a big deal to do.
It's worth it tho. I've had my 4.125 stroke motor for 20k miles with the rev limiter anywhere from 7000-7200 rpm racing the **** out of it.
I am going with a bigger motor though and gonna use a 4" stroke this time to avoid the oil burning issues
Nate
Nate
well i hope you are right cause I made 517rwhp with my 4.125" stroke.
Going with a bigger bore and a 4" stroke so it should make 540rwhp.
Anyone done a 4.125 X 4.125? Of course an engine this large would stress everything to the max.
Is the Eagle crank O-K? Stroker kits in St Charles Mo. told me that there hard to balance or something of that nature.
