LS2 Billet rails and cable bracket
Old Nov 17, 2004 | 09:03 PM
Nasty N8's Avatar
Default LS2 Billet rails and cable bracket
They are here and ready to go the LS2 billet rails and billet throttle cable bracket.
*Complete kit LS2 intake, Billet rails, Billet cable bracket, TPIS TB, injector O-rings and all hose and fittings to bolt directly to you factory feed line.
*Vette kit includes LS2 intake, Billet rails, Nick Williams TB, injector O-rings and all fittings and hose to connect to the stock feed line.
Complete LS2 Kit $1150.99 + TB core
Complete Ls2 Vette Kit $1100.00 +TB core
Billet LS2 Rails $199.99
Billet rails w/ all fittings and hose to factory feed line $340.00
Billet throttle cable bracket $99.99
GM LS2 intake $249.99
GM injector O-ring kit $29.99
TPIS 90mm LS2 TB $489.99 + TB core
Nick Williams 90mm LS2 TB $525.99 + TB core
Have a great day Nate
Attached Thumbnails LS2 Billet rails and cable bracket-ls2-intake-post.jpg   LS2 Billet rails and cable bracket-ls2-intake-006.jpg   LS2 Billet rails and cable bracket-ls2-intake-007.jpg   LS2 Billet rails and cable bracket-ls2-intake-008.jpg   LS2 Billet rails and cable bracket-ls2-intake-009.jpg
Old Nov 17, 2004 | 10:24 PM
BLASTER's Avatar
Nate,
Does the $340 include the parts to replace the factory cross over? Excuse my ignorance, I know nothing about the fuel system. BTW, the kit looks great.
EDIT: What's the core on the TB?
Thanks
Old Nov 17, 2004 | 10:27 PM
Nasty N8's Avatar
Yes it does includes everything needed.
Thanks for the comment.
Nate
Old Nov 17, 2004 | 11:19 PM
Cheatin' Chad's Avatar
Nice set-up Nate!
Old Nov 18, 2004 | 02:56 AM
C4VetteLS1's Avatar
A FAST 90MM TB would be slightly cheaper and not need the core correct?
Old Nov 18, 2004 | 08:00 AM
Green Thunder's Avatar
Nice setup Nate! Looks sweet!
Old Nov 18, 2004 | 10:45 AM
slider417's Avatar
Nate... nice setup.. I am going to assume this will work on the 04 GTO's ?
Old Nov 18, 2004 | 11:56 AM
Nasty N8's Avatar
C4 Vette- it will be slightly cheaper but they have way too many problems and the throttle shaft does not use bearings and sticks. The TPIS is a much higher quality peice.
Slider it will bolt on the 04-05 GTO and the C6 as well.
Thanks guys.
Nate
Old Nov 18, 2004 | 12:14 PM
LOnSLO's Avatar
Nate, are the rails ready to be shipped yet. Haven't heard back from you. Just checking
Thanks
Ryan Young
Old Nov 18, 2004 | 12:27 PM
Nasty N8's Avatar
Yes just got them back late yesterday. I will be calling you shortly.
Nate
Old Nov 18, 2004 | 12:40 PM
LOnSLO's Avatar
You da man!
Old Nov 18, 2004 | 05:10 PM
black_z's Avatar
Very nice piece Nate.
Old Nov 18, 2004 | 05:40 PM
Mirek's Avatar
Thats beautiful. Do you have a turn key kit for us vette guys yet ? Maybe with the N/W throttlebody ?
Old Nov 18, 2004 | 06:00 PM
NA$TY-TA's Avatar
Nate my brutha.... havent talked with ya in a while....... How mant LS2 intake you have in stock??? Ill be needing the intake and the injector O-ring kit... no need for th erails i already have yours.......... Ill check this later tonight or ill give ya a call tomorrow.
Kyle
Old Nov 18, 2004 | 06:01 PM
Classic's Avatar
Very nice Nate!! I also aggree about the FAST tb -- they have had nothing but problems. The TPIS is a nice looking piece as well.
Old Nov 18, 2004 | 06:48 PM
WILWAXU's Avatar
Nate, what do you have to do with the MAP harness? Does it need to be extended?
Awesome kit BTW!
Old Nov 18, 2004 | 07:55 PM
Danny2tek's Avatar
Sweet kit!!!
Old Nov 18, 2004 | 09:05 PM
BLASTER's Avatar
Nate, One question came to mind after we spoke today.....How much Hp can those fuel rails support?
Old Nov 18, 2004 | 09:07 PM
xssive's Avatar
Just to get this straightened out for everyone... If you have aftermarket rails for an ls1/ls6 intake, they have different bracket spacing than the ls2 rails correct Nate?
So you cant just throw aftermarket ls1/ls6 rails on an ls2 intake?
Old Nov 18, 2004 | 09:27 PM
Nasty N8's Avatar
Ya sorry Kyle xssive is right the rails are completly new. The old rails are way off.
Mirek I can do a Nick Williams TB for you it is a great piece as well. I can do a kit for the Vette's W/ intake, TB, rails, O-rings, fittings and hose $1100.00
Blaster you will not have to worry about that for a long time. They will flow enough to support well over 1500HP
Nate
