LS2 Strokers w/Knock Sensors?
Old Feb 11, 2005 | 01:13 PM
  #61
93Polo's Avatar
or Y-body Kooks....
Old Feb 12, 2005 | 05:10 PM
  #62
mikey's Avatar
LS1TECH Sponsor
Here is our solution. This is a 402 LS2 Dominator series engine going together.
Right Side
Left Side
Old Feb 12, 2005 | 05:11 PM
  #63
mikey's Avatar
LS1TECH Sponsor
Originally Posted by JS
Wonder if my Hookers will clear....
They will not...
Old Feb 12, 2005 | 10:24 PM
  #64
DrkPhx's Avatar
Originally Posted by mikey
They will not...
Will any long tube clear?
Old Feb 13, 2005 | 12:36 AM
  #65
JS's Avatar
JS
Looks like TalonWS6 (Tommy) had this figured out 5 months ago.
He was the 1st guys that said just retap the block and most guys laughed.
Now it looks like he was right all along,good info Mikey..
Old Feb 13, 2005 | 07:15 AM
  #66
CHRISPY's Avatar
Originally Posted by Perry Kincy
A true statement however it is misleading. The 92-95 knock sensors for the LT1 are part no 10456126. The 96 sensor (both LT1 and LT4) are part nos 10456287. And widely understood to have less sensitivity to knock.
Perry
yep that is correct!
Old Feb 13, 2005 | 11:39 AM
  #67
mikey's Avatar
LS1TECH Sponsor
It still remains to be seen whether or not this will actually work in real life. The LS1/6 sensors and PCM A to D circuitry is specifically tuned to the particular LS1/6 sensor location. EE folks here knowing the properties of low pass filters know what I mean.
By the end of this week we will know for sure. I plan to intentionally induce some engine knock under part throttle load and see if the sensors pick it up. More of a concern is the possibility of false knock signals induced by the new location of the sensors. I will let everyone know my results.
Old Feb 13, 2005 | 02:47 PM
  #68
pkincy's Avatar
Just an FYI, this will work on the right side but not the left when using Kooks or any Groty style header. I drilled and tapped another location for the left side. Not sure about any other header systems....
Remember the LT1s. The YBods had 2 block mounted KSers. The FBody had 1.
I will be happy with 1 if it will work and I expect it will.
Perry
Old Feb 13, 2005 | 02:49 PM
  #69
pkincy's Avatar
Perry
BTW, the motor arrives Monday and will start the install on Wednesday so we should know in a week or so.l
Perry
Old Feb 13, 2005 | 06:03 PM
  #70
Bink's Avatar
Perry
Thanks! Keep us posted!
Old Feb 14, 2005 | 09:11 AM
  #71
KJ's Avatar
KJ
The LS1/LS6 knock sensors worked for us on the engine we had on our dyno. We used a motor mount hole but realy you can use any hole that will work. All you have to do is adjust sensitivity. John, the Calibration Manager came down to help us tune. He told us that you can put them in the back of the head if you want to, as long as they are adjusted correctly. We used the Dynotech F body headers, and we had just enough room.
Also wanted to tell another little secret that we learned. When you extend your map sensor harness you need to flip the out side wires. The are 3 wires that go to your cam sensor. The one on the left needs to go on right, and the right one needs to go on the left. This will make it reed correctly, and it is very simple to do.
Old Feb 14, 2005 | 09:51 AM
  #72
bmfcamaro's Avatar
any pics of that?
Old Feb 15, 2005 | 08:57 PM
  #73
KJ's Avatar
KJ
Originally Posted by bmfcamaro
any pics of that?
No pics of the cam sensor harness, but I will work on that
Old Feb 23, 2005 | 07:47 PM
  #74
pkincy's Avatar
On my FBody install, both LS1 knock sensors went in the passenger side of the block. No interference with the header there and ez to extend the harness.
The cam sensor was also ez. Just extend it over the motor in the harness and to the cam sensor.
Motor is in. Still waiting on the fuel pump and a oil temp sender. But it should fire up tomorrow.
Perry
Old Feb 23, 2005 | 08:38 PM
  #75
GuitsBoy's Avatar
Congratulation man. Thanks for keeping everyone informed with the progress. We definately appreciate it! Atleast I know I do.
Old Feb 28, 2005 | 05:12 PM
  #76
98C5TT's Avatar
Chris do you have any pictures or could you or somebody tell me what wires go where. I cut and seperated them from the plug and I'm not sure about what color goes where?
There are 3 wires and the plug is marked ABC?
Old Mar 18, 2005 | 09:09 PM
  #77
98C5TT's Avatar
Anyone?
Old Mar 18, 2005 | 09:36 PM
  #78
pkincy's Avatar
Originally Posted by 98C5TT
Anyone?
Hopefully you have the old plug. That will give you the original orientation. From the middle of one of the 402 threads Kris posted that the cam sensor needs to have the middle wire remain there and the right and left wires reversed on the new LS2 plug.
I read that and did it when I extended my cam sensor harness. It is working perfectly (well, at least not setting codes).
Perry
