LS2 Strokers w/Knock Sensors?
Essentially, I am planning to build a N/A motor this winter, purchase an LS2 equipped car (Vette or GTO) over the summer and just swap em out...
Any help would be great!
I disconnected the knock sensors on my supercharged Vette last summer and still no problems with 12lbs on a stock motor.My new motor will also run without knock sensors
. We didn't have knock sensor protection for years.
But that brings up the questions of: Why leave power on the table by running a lower compression ratio and conservative tune with no knock sensors? Isn't that one of the benefits of EFI; being able to run on the ragged edge and allowing the PCM to manage detonation for you without grenading your $$$ engine? From what ir sounds like, there is no immediate fix in sight and probably will keep alot of people from pulling the trigger on this otherwise killer setup.
I saw them talking about possibly using knock sensors from other cars like a
Grand Prix that had the sensors mounted on the side of the block like the LS2.
I'm sure in another month or so we'll know if there's any way to run knock
sensors on an LS2 engine using an LS1/LS6 computer.
At least I hope they find a solution in another month or so since I think a LOT
more people would jump at these LS2 402 combinations if the knock sensors
where usable.
Forged motor's need an unreal amount of detination to wreck the pistons.So I wouldn't worry much about a forged 402 burning up quickly.
Also in my experience way to many folks think more timing is the answer where getting the fuel right is generally way more important. Even with the operating KSers I had the total KR limited to 2 degrees (down from 20 deg) due to false knock from the noise generated by a built motor. So lets don't blow this out of proportion. Order, install and rock!
Perry
BTW, I should have the motor in and the KSers checked out by mid January
Perry
