HELP LS1 injectors in LS2 intake
If anybody has the fix, please let me know ASAP!
Thanks
david.farmer AT metricchemical.com
The LS2 injector 0-rings are the right od but the LS1 injector is smaller id so the injectors flop around in the LS2 manifold injector ports. Been there.
Bruce
I have a set of larger OD and larger thickness o-rings on the way, but I'm not confident at this point. I have a source that has made "sleeves" that reduce the LS2 bore down to LS1 inector size, but I thought someone here might have an alternate solution.
Anybody else??
Looking into G-forces solution
I check, and my intake defintely leaks with the Red LS2 orings installed.
My setup was with ls1 injectors and it ended up working just fine. Not sure the differences going to truck ones.
thanks for stating it worked just fine using oem ls2 fuel rails!
