Ls7 compatability
Old Mar 30, 2005 | 05:00 PM
black99WS6's Avatar
Default Ls7 compatability
I'm looking for a good set or heads for my car. At first I was thinking patriot, but I'm wondering if ls7 heads are compatible to an ls1 and if the flow would be better.
Old Mar 30, 2005 | 07:26 PM
eric01ss's Avatar
there not since the heads of a ls7 are 12' degree and the ls1 is 15' degree you'll have to change pistons
Old May 28, 2005 | 12:26 PM
SDB's Avatar
SDB
Well, I can get some 11 degree heads from ET HEads, and don't have to change pistons....not sure on teh LS7 stuff though.
Old May 30, 2005 | 09:36 PM
slyws6's Avatar
they won't fit, they are designed for a larger bore diameter as well as the intake runners being totally different, you would need a whole LS7 topend (intake, heads etc..) if you went that route. The LS7 heads are based on the C5R heads (or C6R heads now), and they would be overkill on anything smaller than 40x cubic inches.
-Sly
Old Jun 4, 2005 | 12:25 PM
Cary@Perf-Induction's Avatar
Collections Hold
Default ls7
-Sly
if you were to use our new ls7 cylinder heads, you would have a choice between a 4.125 bore version or a 3.9/4.0 bore version that would have a slightly smaller runner and a 2.100 valve instead of the 2.200 stock ls7 valve. It would still require a ls7 intake manifold which should be readily avavlible soon as an aftermarket part.
Old Jun 4, 2005 | 02:17 PM
marco427's Avatar
I was under the impression that LS7 heads are not yet available. If they are, can you provide prices and info on piston options for my C5R block (4.125" bore)?
Old Jun 6, 2005 | 03:45 AM
Collections Hold
Default ls7
I don't think the production LS7 is avalible yet. We are making LS7 "aftermarket" cylinder heads out of our new castings, which are based on the C5R casting. It is much stronger than what a production version will be. 3/4 inch deck etc.
Old Jun 6, 2005 | 06:19 AM
slyws6's Avatar
Do you guys have any flow numbers and pricing yet?
-Sly
Old Jun 6, 2005 | 09:31 AM
marco427's Avatar
Amen.
