clutch ?
clutch
well, I am running a spec stage 3. I just finished breaking it in, when it started slipping the 1st time out full throttle. It's at the shop awaiting teardown and inspection as I type. I was curious to see what others with similar setups were using and if any problems were encountered making this power.
Originally Posted by ZLEEPER
what clutch is everyone using for their 402 ls2?
Rampant
well, it seems there were contributing factors to the failure of the clutch. The slave cylinder is bad, and a freeze plug on the rear of the motor was leaking slightly causing it to slip. Who knew that eagle uses a freeze plug to seal the crank? I sure didn't. Perfect timing being a holiday weekend. Can't seem to find a place open that carries this apparently "special size" freeze plug.
