LS7 block and LS1/LS6 heads.
I'm wondering if regular LS1/LS6 heads will fit on this block?
Also, Have any shops got there hands on the LS7 and/or other parts for evalustion yet?
Those heads and intake are a mandatory pair for the use of either but the block I'd bet will work with all other LS series heads.
I was asking if a set of LS1 or LS6 heads will botl right up to an LS7 block becuase of the changes made to the heads might move the bolts around to make space.
And the ports are larger. They require an Offset rocker to clear the extra space in the port so the pushrod doesn't protrude into the intake port. If that kind of work was done, the Head bolts may have been moved to make room. I've looked @ pics, but they only say so much.
I Don't care about the LS7 heads or LS7 Intake. I'm curious if anyone knows if the regular LS1/LS6 heads will bolt on. That's it.
But, we'll all have to wait and see what the LS7 heads and intake go for. Might be better to go with that or (to save money) go with the regular LS1/2/6 parts.
