LS7 clutch pics
Old Sep 22, 2005 | 12:57 PM
  #101
robertbartsch's Avatar
Does anyone have a part number for a Ls2 flywheel that will work with the Ls7 clutch and LS7 pressure plate?
What about using an LS1 throw out bearing?
Old Sep 22, 2005 | 01:09 PM
  #102
GTO_Scott's Avatar
https://ls1tech.com/forums/showthrea...t=ls2+flywheel
Old Sep 22, 2005 | 01:10 PM
  #103
slt200mph's Avatar
Part no. is 1257611
Old Sep 25, 2005 | 09:14 PM
  #104
BrandonDrecksage's Avatar
any word if this works on ls1 car yet? i'd really like to know cause that'd be my clutch setup.
Old Sep 25, 2005 | 09:54 PM
  #105
TroubledWine3's Avatar
LS7 clutch/pressure plate
LS2 flywheel
  #106
NOSjohn's Avatar
Restricted User
Yes, if you haven't read through the thread. The common components that seem to work are: LS2 flywheel, LS7 clutch and P/P.
Old Sep 25, 2005 | 10:49 PM
  #107
well thats what i'm asking...."that SEEM to work" I would liek a definative anwser because i don't want to order a couple of hundred in parts..and hav eit turn out that it doesn't work...are shops doing this yet? I'm gonna need a clutch soona dn can't isntall it myself.
Old Sep 26, 2005 | 05:40 PM
  #108
yekta's Avatar
subscribing
Old Sep 28, 2005 | 03:16 PM
  #109
JS's Avatar
JS
Just finished the LS2/LS7 clutch install on a customers 370RW SS Camaro
Car feels like stock,no chatter and it grabs like a ****
This is a great option now.....
Old Sep 28, 2005 | 03:35 PM
  #110
eb02z06's Avatar
So JS how is the pedal effort? Does the clutch grab at the same pedal height? I'm assuming no shims or anything were needed? What about the weoght between the older LS1 assembly and the newer LS2 assembly? This is great news so far-but damn I couldn't hold on and bought a Ram Powergrip HD.
Old Sep 28, 2005 | 03:42 PM
  #111
JS's Avatar
JS
No shims,pedal is like stock with only it being slightly higher..
I replaced a Spec III so I dont know the difference from a LS1/Z06 Clutch?
Old Sep 28, 2005 | 03:48 PM
  #112
GuitsBoy's Avatar
This is great news, JS! Thanks for the info.
Old Sep 28, 2005 | 03:53 PM
  #113
fugasi's Avatar
Excellent news. Now, we just need to find out how durable it is...
Old Sep 28, 2005 | 03:57 PM
  #114
GuitsBoy's Avatar
If my stock z06 clutch is any indication, its should be pretty resiliant. My 86K+ street driven clutch is still grabbing pretty hard, and only slipped a couple of times, and never since doing gears.
The new ls7 clutch seems to be similarly constructed, however there physically more clutch and a higher clamp load. It should last quite a while on the street. However, like its predecessor, it might not stand up to too many high rpm clutch dumps on slicks.
Old Sep 28, 2005 | 04:15 PM
  #115
NOSjohn's Avatar
Restricted User
Very cool, thanks for the info. !
Old Sep 28, 2005 | 04:59 PM
  #116
JS's Avatar
JS
We run Dr's on this car.
I'm confident comming out at 3000 should be fine...Is it for an allout race car,no but for a mid to low 12 Sec Street car this might be the ticket
Old Sep 28, 2005 | 05:10 PM
  #117
Exactly. My car is bolt-on right now and at most, it'll be a heads/cam DD/street car with track use every now and then. Sounds like the LS7 clutch is what I'll be picking up verrrrry soon. Thanks for the info/review.
Old Sep 28, 2005 | 06:46 PM
  #118
STS SUPERCAR's Avatar
Default Ls7 Clutch
Now all we need to do is find a light weight billet aluminum ls2 flywheel that will work with the ls7 clutch. Any ideas?
Old Sep 28, 2005 | 06:52 PM
  #119
bad6as's Avatar
so it will work on my 98 z28? i just need to buy an ls2 flywheel. ls7 clutch disk and p/p.
what about the pilot bearing and throw out bearing and do i still use the slave and master from a 01+ f-body? and some part numbers thanks
Old Sep 28, 2005 | 07:29 PM
  #120
slt200mph's Avatar
Someone will make one soon if $$$ is to be made..
By Brett Foote | 2026-06-04 05:00:17
