LS7 clutch pics
I should have everything here tues.
Jim
What is the best combo of lighter flywheel and approx 11" after market clutch.
Have std LS6 at present. LS2 flywheel or this one best option - will all after market clutchs have the same attachement bolt / spacings?
Mike
I read somewhere that an F-body getting an LS7 clutch would need a GTO flywheel. Will a Vette flywheel work too?
I was just unsure whether all LS2s used the same flywheel or if the GTO and Vette might have used different ones. Looks like their the same.
Thanks.
Jim
Jim
Or are you confirming that the '05 with the LS2 is a different flywheel than the C6 vette?
New part number for LS7 Clutch and Pressure Plate:
Part# 24236500 (replaces part#24233650) $260.99
LS2 Flywheel:
Part# 12571611 $161.82
LS1 Pilot Bering:
Part# 14061685 $8.66
