LS7 heads on my 4.100 bored engine?
My engine is bored 4.100 right now. I know the optimum bore for the LS7 heads is 4.125.
What problems will I have with putting the LS7 heads on my 4.100 bored engine?
How much cfm will I lose from the head flow, will it really kill it?
Thanks.
Also, would you still get 'some' ability to run a larger cam than you would with no flycutting, on 15* pistons? IE, I know they aren't 12* cuts, but shouldn't you still get some relief out of the 15* notches?
I think 15* pistons would work ok with the 12* heads. You may not be able to run as big of a cam as if you had pistons notched with 12* reliefs, but I think you'd be able to run a bigger cam than if you had no notches at all.
Can someone confirm this?
Sorry, I guess I just got them confused. As for the LS1 heads, my information came from an Engine Masters magazine and since being corrected I have found that it was false information.
For clarrification purposes the ls1 heads are 15 degree, ls7 12 degree, and c5-r are 11 degree. I don't know if there is much of a difference but one must also take into acount the valve centerline (where the valve stem location is in relation to the center of the bore) comparatively with the ls1.
All these things will influence what bore size is minimum for these heads, what bore size is optimal for these heads in relation to flow, and what gains or losses in piston to valve clearence you'll experience by switching to the ls7 head.
