will this turn 420RWHP?
Old Sep 7, 2005 | 08:50 PM
AntiVenom06's Avatar
Default will this turn 420RWHP?
2000 Camaro ss
M6 - aluminum fly wheel, spec stage 3
LS6 Heads, Hot cam (or TR230unsure yet), long tubes, lanes true duals, port TB, 99 injectors, LS6 intake, 3.73's. lid, LS6 pcv conversion, CIA, and a asp pulley?
Old Sep 7, 2005 | 08:54 PM
eric01ss's Avatar
should be there u still running the stock 10 bolt
Old Sep 7, 2005 | 08:55 PM
yes, shutup i dont wanna hear it, i can only afford this much right now with the rims and all... im good at crossing my fingers however.
Old Sep 7, 2005 | 09:09 PM
11SECDWS6's Avatar
Originally Posted by AntiVenom06
2000 Camaro ss
LS6 Heads, Hot cam (or TR230unsure yet), long tubes, lanes true duals, port TB, 99 injectors, LS6 intake, 3.73's. lid, LS6 pcv conversion, CIA, asp pulley, and 1.8 rockers?
It'll depend heavily on your choice of cams. There's only a handful of cams that will make that power through stock heads. But it can be done.
You sure you want 1.8 rockers?
Old Sep 7, 2005 | 09:22 PM
Whats wrong with 1.8 rockers? What would be best?
As far as the cam, I plan to spray later, and maybe way later FI, I want a decent cam i can live with til I get the money for spray. Then use with my FI also.
Old Sep 7, 2005 | 09:29 PM
Elite_Hot_Rod's Avatar
Nothings wrong with 1.8 rockers but you don't need them, spend your money else where.
Old Sep 7, 2005 | 09:34 PM
So stock LS1 rockers will be fine? Theres no gain from using 1.8's?
Old Sep 7, 2005 | 09:37 PM
11SECDWS6's Avatar
Yes the stock rockers will be fine for just about anything you can do to a hydraulic set up. Put your money somewhere else.
Old Sep 7, 2005 | 09:38 PM
Ha, you have no idea how happy you just made me now that I don't have to buy those exspensive goddamn things!
Old Sep 7, 2005 | 09:39 PM
11SECDWS6's Avatar
Also, depending on how large of lift cam you go with, you might run into some interference between your valve and piston using 1.8 rockers.
1.8 rockers are more for an "all out" effort. I have the feeling you have a ways to go before getting to that stage as do I....
Old Sep 7, 2005 | 09:42 PM
If you were going with a solid roller motor or maybe even a HUGE cam then you'd use better rockers but for most the stock rockers can handle anything you can throw at them. Maybe more suspension mods?
Old Sep 7, 2005 | 09:43 PM
11SECDWS6's Avatar
That where I'm puttin my money right now...suspension...get those 60' times down.
Old Sep 7, 2005 | 09:45 PM
Yea I am replacing the entire suspension, I just didn't list that since I'm trying to finish up my motor plan, I have everything else planned.
It's all in the 60ft, If you can't cut a decent 60 you will never be quick.
Old Sep 7, 2005 | 09:46 PM
Yea, that 10 bolt is scaring me too looking at the suspension mods I am thinking about.
btw thanks for all the help guys <-- im not spending 500+ on rockers
Old Sep 7, 2005 | 09:49 PM
11SECDWS6's Avatar
Use the $500 towards some lower control arms and maybe a torque arm. You'll notice a big difference in how well your car will hook.
Old Sep 7, 2005 | 09:52 PM
Yea like I said above, I already got all that on my list and taken care of, just trying to finish planning the motor.
Can't decide on a damn cam
Old Sep 7, 2005 | 10:03 PM
eric01ss's Avatar
jsut post that since the 10 bolt takes less power and as cams go i would go with a f13 on 114 or a f14 on 114 lsa and not a hot cam or a tr230
Old Sep 7, 2005 | 10:05 PM
The hotcam would make too much power for the 10 bolt?
