402ci LS2 or STS Turbo setup?
a) A nice 402ci LS2 block with AFR heads, big sized cam, the works.
or
b) Keep the engine stock CI's, forge it for turbo and throw on a STS turbo kit and run it at around 5-8psi. Maybe even put on a FMIC if the money agrees with me.
I figured I could make around 450-480rwhp with the LS2 setup. Not too sure how much HP I'd make with the turbo kit. So what would YOU do?
edit: May not be right forum but, what should you do/replace on a engine to prepare it for FI?
hey man, i was just at GMR last monday and i saw their turbo kit. ill just say AWESOME! thats a great deal they got going on too. id definately check it out. i prefer the front mount over the sts too. GMR made 406rwhp that kit and the car is a automatic and the trans was slipping alot too so theres alot more in the kit.
To get 553rwhp from the STS, you will be shortening the life of you stock motor for sure. On the contrary, my motor is now rock solid, forged everything held together by ARP. I am very happy with my choice.
I got mine built by SDPC, and although I will likely drive it NA initially, it is built to handle up to 15 pounds of boost, so when the power bug strikes again I'll be ready.
I agree with what 89FormulaLS2 said about cost. I thought about doing a 383 stroker with my stock LS6 block, but I can do a LS2 402 short block for about the same money.
Don't get me wrong - I am a fan of the STS turbo system, and I STILL plan to install one in the near future. But a little insurance from building the motor never hurts.
Or how about a trip to the mound as Oswald is getting his teeth kicked in in the 5th?? Break up the Sox's momentum...
I coach my ten year old's little league team and even and I could've managed that game better than he did!!
Oh yeah, go with the 402 (...Again he says...)
or
LS2 all the way!
