LS7 PCM & Harness
Old 10-27-2005, 10:01 AM
Builder's Avatar
Default LS7 PCM & Harness
Until there is a specific location for this information, perhaps we should post what we think will work. My LS7 will be here tomorrow and going in the car next month.
PCM options:
BigStuff3
Accel DFI Gen 7
Harness options:
GM
Old 10-27-2005, 03:41 PM
Builder's Avatar
The Delphi MEFI 4B may work as well. I don't know about the harness yet.
Old 10-28-2005, 02:46 AM
Bink's Avatar
Originally Posted by parts@sdpc
First round of crate LS7's from GM --- approximatley 100 engines. Demand is much greater than the supply! We will see some more availability after the first of the year and I expect the pent-up demand will have subsided some by then. But, the supply will still be limited. We have been working with a supplier on ECU's, prototypes are finshed! I think we will have some units here by mid-December.
Here's a link -> https://ls1tech.com/forums/generation-iv-internal-engine/399865-ls7-crate-available.html
Old 10-28-2005, 10:56 AM
Builder's Avatar
Thanks, Blink. It appears there are a number of companies that have an ECU and harness for the LS7 already available. All are using the Delphi MEFI-4B and pricing starts around $1,895. Some offer more than others with regard to software and programming. More info to come, but, this will be the path I take unless a sequential system becomes available. The MEFI-4B is a time-tested unit that suits my application (no specific ECU requirements). It may work well for swaps, too.
Old 10-28-2005, 11:23 AM
Bink's Avatar
Keep us updated on your Ultima GTR. That is one mean machine!!
Old 10-28-2005, 12:09 PM
hitmeoff's Avatar
That Ultima is soooo f'n G!!!!!
Old 10-28-2005, 01:30 PM
Moderator
John B's Avatar
Scott, could you please list them for us?
Old 10-28-2005, 09:59 PM
Builder's Avatar
There were other Delphi dealers, too, but these were the folks that really seamed to know what they were talking about. They have LS7 installations running. Todd from Autigent was on his way to SEMA, but really offered extensive knowledge. They are also deeply involved with GM's racing program.
Old 10-29-2005, 11:51 AM
Moderator
John B's Avatar
Thanks Scott. Looks like there's one more that ha one in work http://www.fuel-injection.com/HomePage.htm
Old 10-29-2005, 07:18 PM
Gary Z's Avatar
Electromotive
Old 10-30-2005, 03:43 PM
MEFISTUFF's Avatar
Try r&d dyno in Gardena, He Has Mefi 4 ecu's, software, And Harnesses for
ls7 as well as ls1,2,etc
Old 11-01-2005, 04:25 PM
pcf_mark's Avatar
Do you have contact info for R & D dyno? some of the link above are not too clear about their goal. I want a controller that gets my LS7 running out of the box that I can tweak with some available software to make it run perfect with my combination. Not too picky eh?
Thanks!
Old 11-01-2005, 09:50 PM
Builder's Avatar
Originally Posted by Gary Z
Nice stuff, that Electromotive. I know a guy that's got it on his turbo Ultima CANAM. I think they use a bolt-on 58-tooth reluctor as standard.
Old 11-02-2005, 04:25 PM
MEFISTUFF's Avatar
R&D dyno 310 516 1003
Old 11-18-2005, 04:36 PM
Builder's Avatar
LS7 PCM security was cracked today. The next step is to understand the programming. The vendor has asked to remain un-named, however they are well-known company. They say they'll be offering the PCM and harness in about 30 days. No pricing yet.
Old 11-18-2005, 06:07 PM
bmfcamaro's Avatar
there is a company that said there new hardware will work with LS2 and LS7 stuff. i would imagine the same that you are talking about.
Old 11-18-2005, 06:59 PM
Builder's Avatar
It's not a company that makes an ECU or a stock PCM re-programmer. They are simply tweaking the GM unit and will be selling it with the necessary programming for swaps. In my case, all I need is fuel and spark (and a descent power tune)...but, none of the body control, traction control, etc. is required for my "swap". This type of programming won't be good for a C6-Z06, but would be good for a C5 or F-body (I think). We'll have to see what they come up with...
Old 11-18-2005, 07:49 PM
98blackSS's Avatar
Thanks Scott.. you have mail
Old 11-18-2005, 09:28 PM
LS2 V8 Miata's Avatar
Default Already been done, Modded OEM
The 2006 LS2 crate engines are already being run "stand alone" (put the LS2 engine package in any car) with GM OEM PCMs running Delphi 5 wire MAFs and aftermarket wiring harnesses, including running the 90 MM FBW Throttle body. Just not being done by GM people or GM marketers.
Other independent guys are frenzied out trying to be first with the right power MAP in a MEFI IV and wiring package for these motors, don't hold your breath and get ready to shell out for a cable operated 90 MM throttle body.
Old 11-18-2005, 10:13 PM
98blackSS's Avatar
Which OEM PCM are you referring to?
Just curious
Quick Reply: LS7 PCM & Harness
