slp402/ls2 with afr heads/how much power?
Old 12-20-2005, 03:32 AM
bernard shortt's Avatar
Default slp402/ls2 with afr heads/how much power?
i have a ws6 2002 ram air t/a with slp 402 stroker with afr heads from TEA bored to 330cc flow,c5 maf/mti lid/mezerie water pump/slp radiator,fans switch/accufab tb,and bellow,spohn torque arm and drive shaft,strange 12 bolt with 4'10 gears all kinds of suspension upgrades with hal shocks/slp underdrive pulleys 42 lb injectors with racetronics fuel pump plug and play,with tuning and dyno from MORE PERFORMANCE, edlelbroch exhaust, T-REX CAM from thunder racing
guess the rwhp???
what else can i do besides nitrous????
RWHP IS AT 456,,i thought i'd surely be at 500hp,,
Old 12-20-2005, 09:11 AM
DrkPhx's Avatar
Part of it may be the cam, which is small for a stroker. But you didn't mention what intake (LS6 or FAST 90mm) you are running. I assume those are 225 heads (not 205cc) and did you buy the assembled CNC version and have TEA port them or buy bare casting and have them ported? What head gaskets did you use? Another point is the 12 bolt and steel DS will eat up a little more hp.
Old 12-20-2005, 09:22 AM
BigBronco's Avatar
T-rex is MORE then ample to support 500 rwhp NA..
do you have a dyno graph now?
What do your heads FLOW? I take it, ,that is what you meant when you said they were "bored to 330 cc"
I have seen many 402's make 500 rwhp easy on top of other 540 rwhp ls2's. Check the tune and heads and what not... definately can make more power with that cam in it, that is for sure.
Old 12-20-2005, 09:48 AM
slow trap's Avatar
do you know your c/r ?
Old 12-20-2005, 03:24 PM
BigBronco's Avatar
this man has left us with soooooo little LOL
Old 12-21-2005, 05:02 AM
i have the ls6 manifold witha c5 maf the granetelli i had would not let the car tune it kept reading lean /rich,,lean rich on the dyno .my throttle body had to be ported also.my heads are afr's bored to 330cc flow with i think just regular gm gaskets ,it was assembled by TEA in OHIO
Old 12-21-2005, 05:09 AM
how much nitous can i run safely in this slp 402 stroker/with compression at 11:1 //because i don't think the fast intake and fast tb will make that big of difference,ntg would be just as cheap and probably alot more power,i just hope my carolina clutch will hold its rated to 800 hp
Old 12-22-2005, 08:35 AM
Restricted User
98Z28CobraKiller's Avatar
I have an SLP402 w/ their head/cam combo sitting down stairs in pieces. Waiting for some more parts to come in but my setup will be very similar. I don't have the 12 bolt rear which I hear eats some hp. Also, are you A4 or M6. A4 eats some hp on the dyno also. I will let you know on mine as it goes together.
Old 12-24-2005, 08:57 AM
Restricted User
I started pulling my LS1 yesterday. I have everyhting that i need. Hopefully this will be done by Jan 1 and I can tell you how it runs.
Old 12-24-2005, 09:51 AM
beardWS6's Avatar
What kind of exhaust are you running. Maybe your choking it? Also if your a A4 will ear some. The fast90/90 would get you another 20-25 rwhp. But it looks like your not running a good exhaust system to me. Kooks 1 7/8 with cut-out is what you need!
Old 12-26-2005, 02:49 AM
jet hot headers with edelbroch exhaust and 3" cutouts no cats but have a edelbrock muffler
Old 12-26-2005, 02:51 AM
i have the m6 t56 factory for now until it breaks with a spohn drive shaft
Old 12-26-2005, 08:21 PM
pkincy's Avatar
Don't be disappointed yet. Some cars are dyno queens and some are not. My 402 with a baby cam pulled 484 rwhp, yet a buddies with a similar setup only pulled 456 rwhp. Yet his first day out he ran a 134 trap speed. So there is plenty of power there.
Enjoy,
Perry
Old 12-27-2005, 10:18 AM
jz06man's Avatar
Perry Kincy
What baby cam are you running.. I too might go to a 402, but with a very light cam..
Thanks
Old 12-27-2005, 11:41 AM
pkincy's Avatar
I am using the TSP Torquer. And it produces over 480 rwhp with only the ported TB and Z06 intake. It has an incredibly flat torque curve with 400 ftlbs from 3000 rpm up to redline.
PK
Old 12-27-2005, 01:13 PM
jhong321's Avatar
I am also running a baby cam 226/226 lsa 112 .600 lift with the Patriot heads stage 2.(205) and a ls6 intake. and ported TB on my 402 and put out 473 rwhp and 489 rwtq. I am a firm believer in baby cams just for the driving fun of the car and nice tq. levels.
Old 12-27-2005, 02:06 PM
pkincy's Avatar
What rpm does your car hit 400 lb ft and how long does it hold it?
A number that I find far more important than the peak numbers that so many drag only builders shoot for.
Perry
Old 12-27-2005, 02:11 PM
383ss's Avatar
puttting the Trex in there was a mistake. I've said this a dozen times,. that cam was designed for STOCK HEADS and STOCK DISPLACEMNT. why on earth would you put it in anything else??
your heads weren't bored to 330cc. that is the intake runner displacement. do you know what they FLOW, at 100-600 lift?
Old 12-29-2005, 10:30 AM
WS6snake-eater's Avatar
factory clutch???....you are probably blowing through the clutch at that power level, which is also robbing you of some good power.
Old 12-29-2005, 02:26 PM
BlueSix's Avatar
It's the heads and cam.
I still haven't seen any good results from AFR heads that were worked over by TEA.
Quick Reply: slp402/ls2 with afr heads/how much power?
